I am ready to merge a very large change to Geonetwork:
https://github.com/geonetwork/core-geonetwork/wiki/JPA-Data-Layer
The change removes the old DBMS and raw SQL database access and replaces it with a data model and JPA/Hibernate data access.
The change required a deeper integration of Spring as well as several support classes for writing integration tests as JUnit tests.
Please vote (or comment) on this issue so I can merge it onto the baseline.
Thank you,
Jesse
Hi Jesse, really nice work.
I’ve been testing it in the last days and it’s much more comfortable to work with. The application is working fine even if they are still minor stuff to fix.
A merge to the develop branch is fine for me. We’ll use develop branch for some projects (eg. GéoSource), so we’ll test it a lot in the coming weeks.
+1 for me.
Francois
2013/11/5 Jesse Eichar <jesse.eichar@anonymised.com>
Thank you,
Jesse
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Hi Jesse,
Indeed this is a huge amount of work that is very appreciated.
I’m looking foward to implementing a new service with easy DB access =)
+1
Could you please inform us when the merge is done ?
Thanks
On Tue, Nov 5, 2013 at 12:14 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
+1 for me.
Francois
Florent Gravin
Camptocamp - Chambéry
0479444492
Thank you,
Jesse
Hi Jesse,
Greta work! Thanks for investing so much time in this!!
+1 from me
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer, MapServer, PostGIS and GeoNetwork. Visit http://geocat.net for details.
_________________________Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
http://geocat.net
Op 5 nov. 2013 om 11:38 heeft Jesse Eichar <jesse.eichar@anonymised.com> het volgende geschreven:
Thank you,
Jesse
Hi
+1, looks a really nice feature. Thanks for the good work, Jesse.
Jose García
On Tue, Nov 5, 2013 at 2:59 PM, Florent Gravin <florent.gravin@anonymised.com89…> wrote:
Hi Jesse,
+1
Thanks
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
+1 for me.
Francois
Florent Gravin
0479444492
Thank you,
Jesse
