[Geonetwork-devel] Query Maps inserting coordinates
Hello,
Actually the feature I wanted is the same as you want. A bounding box where the user can make his own selection and results shows up, just like “ArcCatalog” search. But I thought that it was not implemented so far, so I didn’t ask about this feature. Maybe that feature can go to user’s wish list.
Thanks for the tip, I’ll try to make some queries using it so I’ll see if I have the same problems.
Sorry about my bad english.
See ya,
Felipe Costa
pgrzeszc@anonymised.com wrote:
I am also interested in this. As a matter of fact, picking coordinates on a map would also be a great feature. Let’s say you start with a map of the world, you could zoom in on an area and drag a box around the area of interest to submit coordinates. I’ve seen applets that perform a similar function.
With respect to your query Felipe, I think that you would have to edit the regions.xml file under web/xml/ directory, to add your region and coordinates.
I actually tried this just now, and the location name shows up in the pull down menu in advanced search, but the results are not quite what I expected. Perhaps there is some logical problem with the overlapping/enclosing coordinates. Take the following scenario: Out of 426 total metadata entries, the search returns 9 that overlap, 375 that enclose, 370 that are fully outside of and 342 that are a particular location (about 0.05 degrees x 0.05 degrees). It seems to me, that if a dataset encloses a location should also overlap it. Also, evidently, judging from the result numbers, some locations that are fully outside of the specified area also enclose it. How can that be?
Let’s say that some of the datasets have the wrong coordinates specified, so that could contribute to the problem - I didn’t fully examine all of them. However, I can’t figure out why a particular dataset, whose coordinates I verified, would show up in both the ‘encloses’ results as well as the ‘fully outside of’ results.
Is anyone else having this problem?
–paul
Paul Grzeszczak
GIS Analyst / Programmer
Dept. of Earth Sciences
University of Windsor
Felipe Costa <fsc7@anonymised.com>
Sent by: geonetwork-devel-admin@lists.sourceforge.net
2006-02-09 10:26 AM
To
Geonetwork Devel <geonetwork-devel@lists.sourceforge.net>
cc
Subject
Hello Developers,
I’m using a lot geonetwork to discover it’s capabilities and thanks for you all helping me about my questions. I have one more today.
Is it possible to make a query inserting a pair of coordinates and recovering maps that match to this coordinate?
How’s that possible? I tried but I couldn’t make it. I saw in the advanced search a field which have some options like “is in”, “is not in”,“is completely out”, etc… But I don’t know how to use it. Can you explain it to me?
Thanks in advance,
Felipe Costa
Brings words and photos together (easily) with
PhotoMail - it’s free and works with Yahoo! Mail.
| Felipe Costa w|
| fsc7@anonymised.com w|
| Desenvolvedor Web w|
Relax. Yahoo! Mail virus scanning helps detect nasty viruses!
Regarding the bounding box coordinates selection:
How about incorporating LiveMap ( http://tmap.pmel.noaa.gov/~callahan/JAVA/map_v3.0/LiveMap_v3.0.html ) or JazPanel ( http://nsidc.org/data/tools/jaz/ )?
The code is available for both of these, and perhaps it wouldn’t be too difficult to implement.
–paul
Paul Grzeszczak
2006-02-09 12:37 PM
To
cc
Subject
Re: [Geonetwork-devel] Query Maps inserting coordinates
Hello,
See ya,
Felipe Costa
I actually tried this just now, and the location name shows up in the pull down menu in advanced search, but the results are not quite what I expected. Perhaps there is some logical problem with the overlapping/enclosing coordinates. Take the following scenario: Out of 426 total metadata entries, the search returns 9 that overlap, 375 that enclose, 370 that are fully outside of and 342 that are a particular location (about 0.05 degrees x 0.05 degrees). It seems to me, that if a dataset encloses a location should also overlap it. Also, evidently, j udging from the result numbers, some locations that are fully outside of the specified area also enclose it. How can that be?
–paul
Paul Grzeszczak
2006-02-09 10:26 AM
To
cc
Subject
[Geonetwork -devel] Query Maps inserting coordinates
Hello Developers,
Thanks in advance,
Felipe Costa
| Felipe Costa w|
