[GeoNetwork-devel] Questionable compressed js files in the repo...
I was attempting to correct trac ticket 954 which is a simply typo change
and I noticed some files in the repository that are questionable.... Since
you are the experts I thought I would run it by you.
The following files seems outdated and the are automatically regenerated
when doing a "mvn clean install"
web-client/src/main/resources/apps/search/js/App-mini.js
web-client/src/main/resources/apps/js/GeoNetwork-mini.js
web-client/src/main/resources/apps/js/GeoNetwork-mini-nomap.js
The next file, I cannot find any reference to to its usage - it has the same
cryptic code as the other compress js files. - It is not automatically
generated so I'm not sure where it came from . It seems like it was
initially committed as a bulk add. I cannot see how anyone can maintain this
file? So I think it should be removed.
web-client/src/main/resources/apps/js/GeoNetwork.js
Thanks.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Questionable-compressed-js-files-in-the-repo-tp4982992.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
One thing I do is use
git update-index --assume-unchanged
so that I never see that they are changed, then it is as if they are not in my index and I can go on with life. I personally don’t think they should be in the index but I am not terribly strongly opinionated about the issue.
See http://gitready.com/intermediate/2009/02/18/temporarily-ignoring-files.html
on more about the update-index to ignore files that are tracked by git.
Jesse
On Thu, Jun 21, 2012 at 3:16 PM, ianwallen <ianwallen@anonymised.com> wrote:
and I noticed some files in the repository that are questionable… Since
when doing a “mvn clean install”
generated so I’m not sure where it came from . It seems like it was
Thanks.
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
Thank you for the information Jesse - I found the git information to be
useful
I must be more opinionated that you! I don't see why these files in the
repository in the first place. They are not providing any benefit. And if
they are going to be in the repository, then they should be, at least, up to
date - which they are not.
For now, I will place them in the index.
I just wanted to bring it up to the group so that someone with a better
understanding of the requirements of these files can review them to
determine if they are really needed.
Again, thanks
View this message in context: http://osgeo-org.1560.n6.nabble.com/Questionable-compressed-js-files-in-the-repo-tp4982992p4983187.html
I agree that these files are build artifacts, and should not be in the repository – it’s confusing and runs the risk they’re out of date.
Kind regards
Heikki Doeleman
useful
I must be more opinionated that you! I don’t see why these files in the
Again, thanks
Should we vote on keeping them in or out?
I am +1 for removing them.
Jesse
Kind regards
Heikki Doeleman
useful
Again, thanks
I am also +1 for removing them.
Simon
________________________________________
Sent: Tuesday, 26 June 2012 12:44 AM
To: tropicano@anonymised.com
Cc: ianwallen; geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Questionable compressed js files in the repo...
Jesse
On Mon, Jun 25, 2012 at 4:37 PM, heikki <tropicano@anonymised.com<mailto:tropicano@anonymised.com>> wrote:
I agree that these files are build artifacts, and should not be in the repository -- it's confusing and runs the risk they're out of date.
Kind regards
Heikki Doeleman
On Fri, Jun 22, 2012 at 1:03 PM, ianwallen <ianwallen@anonymised.com<mailto:ianwallen@anonymised.com>> wrote:
useful
Again, thanks
Exclusive live event will cover all the ways today's security and
GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@anonymised.comforge.net>
geonetwork-devel List Signup and Options
+1 for me
Jesse
Kind regards
Heikki Doeleman
useful
Again, thanks
+1 from me
Op 26 jun. 2012 om 08:08 heeft Francois Prunayre <fx.prunayre@anonymised.com> het volgende geschreven:
+1 for me
Jesse
Kind regards
Heikki Doeleman
useful
Again, thanks
0 (neutral) from my side.
Sorry but it is toooo technical for me J
Patrizia
From: Jeroen Ticheler [mailto:jeroen.ticheler@…437…]
Sent: 26 June 2012 07:59
To: Francois Prunayre
Subject: Re: [GeoNetwork-devel] Questionable compressed js files in the repo…
+1 from me
Op 26 jun. 2012 om 08:08 heeft Francois Prunayre <fx.prunayre@…31…> het volgende geschreven:
+1 for me
Jesse
Kind regards
Heikki Doeleman
useful
Again, thanks
i would say +1
they don’t have to be here
On Tue, Jun 26, 2012 at 5:16 PM, Monteduro, Patrizia (NRL) <Patrizia.Monteduro@anonymised.com> wrote:
Patrizia
From: Jeroen Ticheler [mailto:jeroen.ticheler@anonymised.com]
Cc: ianwallen; geonetwork-devel@anonymised.comrge.net
+1 from me
+1 for me
Jesse
Kind regards
Heikki Doeleman
useful
Again, thanks
GeoNetwork-devel@anonymised.com.net
