Hi All,
I am a bit worried about the use of the "enumeration" type in the
CI_RoleCode. CI_RoleCode is of type "CodeList" and is *not* an enumeration.
It can be extended by the users.
Is it the intention of GeoNetwork to make this a real 'enumeration' type?
An alternative is to use the "codeList" attribute of the code list type
elements to link directly to a URL for the relevant code list. eg.
<CI_RoleCode
codeList="http://www.anzlic.org.au/ANZLICProfile/codeLists/CI_RoleCode.xml"
codeListValue="author">author</CI_RoleCode>
The URL is fictitious but is likely to exist in the future.
If there is a firewall problem then the CI_RoleCode.xml file could be located
on the local system and an OASIS Catalog XML file used to reference the local
copy.
Thanks.
John
-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] On
Behalf Of Andrea Carboni
Sent: Saturday, 7 October 2006 11:52 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] [SPAM] [GeoNetwork-users]
[GN] : add anauthor for a datasetHi all,
I added the 'author' entry to the RoleCd in both GN 2.0.3 and 2.1.0
Andrea> Hi Pierre,
> Back to the list.
> On Oct 6, 2006, at 2:12 PM, Pierre LAGARDE wrote:
> > Hi Jeroen,
> > No, it is a role included in the 19115 definition (if it were a
> > custom role, I would not have sent in the mailing list). I think
> > you forgot it but it’s not crucial (;-)… but in france
(and perhaps
> > in the whole wide world ?) people like to be identified
as an author..
> > Francois could commit this fix but we propose you to
identify all
> > minor errors in the 19115 schema and to commit a new
schema in one
> > or two weeks.
> Good, no problem, except that codelist changes will have no side
> effect on the system. So you may consider committing that
small fix
> to the V2_0_FIX2 if its of use in version 2.0.3
> Ciao,
> Jeroen
> > Cheers,
> > Pierre.
> > De : Jeroen Ticheler [mailto:Jeroen.Ticheler@…1…]
> > Envoyé : vendredi 6 octobre 2006 13:46
> > À : p.lagarde@...39...
> > Cc : François Prunayre
> > Objet : Re: [SPAM] [GeoNetwork-users] [GN] : add an author for a
> > dataset
> > Importance : Faible
> > Hi Pierre,
> > Don't want to distract the whole mailing list with my question
> > Is author a new role that you want to have included or is
it part
> > of the updated 19115 definition?
> > As you have seen, Francois has commit access to
GeoNetwork, so he
> > may commit fixes to the CVS where needed. So if this is a fix to
> > the schema and not a custom role, he could add it today
and it will
> > be included in the 2.0.3 fix release we will generate on Monday.
> > Ciao,
> > Jeroen
> > On Oct 6, 2006, at 8:18 AM, Pierre LAGARDE wrote:
> > Hi all,
> > If we want to add a party with the role of “author”
(definition in
> > 19115 : party who authored the resource ) for the data (in
> > RespParty), you have to correct the actual schema in GN :
> > Go to [GN directory]/web/xml/schemas/iso19115 and open the
> > schema.xsd. Search the sentence:
> > <xs:attributeGroup name="attlist_RoleCd">
> > <xs:attribute name="value" use="required">
> > <xs:simpleType>
> > <xs:restriction base="xs:token">
> > <xs:enumeration value="resourceProvider"/>
> > <xs:enumeration value="custodian"/>
> > <xs:enumeration value="owner"/>
> > <xs:enumeration value="user"/>
> > <xs:enumeration value="distributor"/>
> > <xs:enumeration value="originator"/>
> > <xs:enumeration value="pointOfContact"/>
> > <xs:enumeration value="principalInvestigator"/>
> > <xs:enumeration value="processor"/>
> > <xs:enumeration value="publisher"/>
> > </xs:restriction>
> > </xs:simpleType>
> > </xs:attribute>
> > </xs:attributeGroup>
> > And add <xs:enumeration value="author"/> after publisher (and
> > before </xs:restriction>). Don’t forget to save.
> > Restart GN and it will be good when you create/modify a metadata !
> > In the french context, it could be very important because
the author
> > (s) have specific copyrights.
> > Pierre.
> > Ce message a ete verifie par MailScanner pour des virus ou des
> > polluriels et rien de suspect n'a ete trouve.
> > Les donnees et renseignements contenus dans ce message sont
> > personnels, confidentiels et privés.Toute publication,
utilisation
> > ou diffusion, meme partielle, doit etre autorisee.
> > Any data and information contained in this electronic mail is
> > personal, confidential and private. Any total or partial
> > publication, use or distribution must be authorized.
> > Take Surveys. Earn Cash. Influence the Future of IT
> > Join SourceForge.net's Techsay panel and you'll get the
chance to
> > share your
> > opinions on IT & business topics through brief surveys --
and earn
> > cash
> > http://www.techsay.com/default.php?
> > page=join.php&p=sourceforge&CID=DEVDEV
> > <mime-attachment.txt>
utilisation
utilisation
chance to share your
opinions on IT & business topics through brief surveys -- and
earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge
&CID=DEVDEV
GeoNetwork-devel mailing list
