Hi Norman,
This email remained unnoticed I think… I’m sending the reply to the geonetwork-devel list so others may come up with much better ideas than mine!
For sure there is no existing integration with an informix database.
Maybe a metadata dump into some location accessible to GeoNetwork in XML form could be the quickest way. Work is underway to harvest from a remote (or local) directory (optionally filtering through an XSL and validating) and keeping the GeoNetwork node in sync with that directory.
Ciao,
Jeroen
On 12 Sep 2005, at 18:59, Norman Barker wrote:
I am looking into using Geonetwork for an image catalog application, I particulary like the idea of geonetwork reading the metadata from an external database.
I would be grateful if any one could give me an estimate of the time required to integrate Geonetwork with an informix database with the
geodetic datablade, so the database implements SFSQL, containing product metadata. If Geonetwork already integrates with informix then fantastic, I can start using it!Many thanks,
Norman
