Hi Francois,
I would actually like to use a different map. May be a flash based solution that would load faster and is not dependent on a WMS service. Also, the QuickWMS does not run on Safari on the Mac… I’m not sure what causes that, but it seems inherent for some of the map clients MapBuilder has the same issue.
So I would suggest that if you know of a good, lightweight browse map build in Flash (not a Java applet!) than we can work on getting that into the opensource verison.
Ciao,
Jeroen
On May 16, 2006, at 8:55 AM, François Prunayre wrote:
Hi Jeroen, on the FAO Geonetwork node quickWMS is used to make an interactive area to search on …
Is there any plan to have it by default on Geonetwork ? I had a look to the HTML code, and I could clean it a little bit and make an “how-to add QuickWMS” on that topic ?What do you think about that ?
Ciao. Francois
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n’a ete trouve.Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privés.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and private. Any total or partial publication, use or distribution must be authorized.
