==============Original message text===============
Date: Fri, 05 Sep 2008 22:23:40 +1000
Subject: Re: [GeoNetwork-devel] suggest on geonet:choose elements
Hi Francois,
Sorry I didn't respond earlier to your email about this - I think I've
already implemented something like this - the file is
schema-substitutes.xml (one in each schema directory) because I already
had some profiles that for example wanted to substitute an element for
gco:CharacterString - something that would have forced a choose on every
element in the editor You just specify the field you want to force in
that file and the GN schema parser will override the choices it would've
created from a substitution group with whatever you specify in there.
Simon
On Fri, 05 Sep 2008 21:43:13 +1000 Francois-Xavier Prunayre wrote:
I'm playing with schema-suggestion.xml and was wondering if we could use
it to force a geonet:choose sub elements.
For example, could we set all gmd:Date as gco:Date and don't want to
have to select between a Date or a DateTime
<field name="gmd:date">
<suggest name="gco:Date"/>
</field>
Thanks for your help.
Francois
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________GeoNetwork-devel mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork===========End of original message text===========
