[Geonetwork-devel] Re: Translate Files
Dear Lin Xin,
Thanks for the files! I have changed the encoding to UTF-8, will send you a sample to check they are indeed correct still.
Did you manage to get the translations to work on your site? Or are you waiting for us to incorporate them before you can proceed?
Last question, I plan to move away from the graphics used for buttons, to make it easier to customize the look and feel of the whole website, using CSS also for the button-styling. Could you provide the strings used for the buttons in the following structure (to be put in the strings.xml file?
  <buttonAccept>Accept</buttonAccept>
  <buttonAdd>Add</buttonAdd>
  <buttonAddNewGroup>Add New Group</buttonAddNewGroup>
  <buttonAddNewUser>Add New User</buttonAddNewUser>
  <buttonAdvancedSearch>Advanced Search</buttonAdvancedSearch>
  <buttonBack>Back</buttonBack>
  <buttonBatchImport>Batch Import</buttonBatchImport>
  <buttonBrowse>Browse</buttonBrowse>
  <buttonCancel>Cancel</buttonCancel>
  <buttonClear>Clear</buttonClear>
  <buttonCreate>Create</buttonCreate>
  <buttonDecline>Decline</buttonDecline>
  <buttonDefaultSearch>Default Search</buttonDefaultSearch>
  <buttonDelete>Delete</buttonDelete>
  <buttonDescription>Description</buttonDescription>
  <buttonDownload>Download</buttonDownload>
  <buttonEdit>Edit</buttonEdit>
  <buttonGroupManagement>Group Management</buttonGroupManagement>
  <buttonImport>Import</buttonImport>
  <buttonInsertXMLMetadata>Insert XML Metadata</buttonInsertXMLMetadata>
  <buttonInteractiveMap>Interactive Map</buttonInteractiveMap>
  <buttonLogin>Login</buttonLogin>
  <buttonMap>Map</buttonMap>
  <buttonNewMetadata>New Metadata</buttonNewMetadata>
  <buttonPrint>Print</buttonPrint>
  <buttonPrivileges>Privileges</buttonPrivileges>
  <buttonRemove>Remove</buttonRemove>
  <buttonReset>Reset</buttonReset>
  <buttonSave>Save</buttonSave>
  <buttonSaveAndClose>Save &amp; Close</buttonSaveAndClose>
  <buttonSearch>Search</buttonSearch>
  <buttonSubmit>Submit</buttonSubmit>
  <buttonTabbedView>Tabbed View</buttonTabbedView>
  <buttonUpload>Upload</buttonUpload>
  <buttonUserManagement>User Management</buttonUserManagement>
Jeroen
On 2 Dec 2004, at 07:19, linxin@anonymised.com wrote:
Dear Jeroen and Roberto:
  I send the GB2312 encoded XML,HTML files and Image files to you. Thank you for your help.
Sincerely yours,
Lin Xin,
Global Change Information and Research Center (GCIRC)
Institute for Geographical Sciences and Natural Resources Research(IGSNRR),
Chinese Academy of Sciences (CAS)
<SendFiles.zip>
