[GeoNetwork-devel] Re : What happend with my URL
Hi Pierre,
If you’re running Geonetwork on jetty you could use GAST to change the servlet name.
Otherwise you should do it manually changing the config files (config.xml, web.xml, index.html … ).
Concerning the srv/*, not sure, but I guess it is a Jeeves constraint using services in Geonetwork.
Mathieu
On Wed, Oct 22, 2008 at 1:13 AM, Pierre Gourrier <pierre.gourrier@anonymised.com> wrote:
Hi Mathieu. Many thanks for answering.
No, I didn’t… I’ve just used it to create the DB.
Do you know where’s the /srv/** is defined?
Thanks.
Pierre Gourrier
----- Message d’origine ----
De : Mathieu Coudert <mcoudert@anonymised.com>
À : pierre.gourrier <pierre.gourrier@anonymised.com>
Cc : geonetwork-devel@lists.sourceforge.net
Envoyé le : Mardi, 21 Octobre 2008, 14h33mn 15s
Objet : Re: [GeoNetwork-devel] What happend with my URL
Hi Pierre,
Did you use GAST to change the servlet name?
Mathieu
On Tue, Oct 21, 2008 at 8:00 PM, pierre.gourrier <pierre.gourrier@anonymised.com…> wrote:
Hello.
I’ve just finished customizing a GN application (from the trunk) for the
needs of my company.
I’m going to deploy this new GN on the Web (so Tomcat integrated in Apache).
I got a problem!!
My entire URL is not well formed. I’ll explain.
In my localhost, a service (for example the login service) is pointed like
this http://localhost:8080/srv/en/user.login
If I look in the standard GN (from the installer) this URL is
http://localhost:8080/geonetwork/srv/en/user.login
Where did this /geonetwork go in my application? How can I do to get my URL
well formed?
Can you help me?
Thanks
Pierre Gourrier
View this message in context: http://www.nabble.com/What-happend-with-my-URL-tp20095975p20095975.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
GeoNetwork-devel mailing list
Mathieu Coudert
Mathieu Coudert
