[GeoNetwork-devel] Re wms / intermap problem
wow, it is working
thank you very much !!
----- Original Message -----
From: "François-Xavier PRUNAYRE" <fx.prunayre@anonymised.com>
To: <peturkirke@anonymised.com>
Sent: Tuesday, November 07, 2006 7:05 PM
Subject: Re [GeoNetwork-devel] wms / intermap problem
Hi Petur, could you try to add the EPSG:4326 (WGS84) code to you mapfile
WEB / METADATA / "ows_srs" "EPSG:4326 EPSG:32629"
I'm not sure Intermap could deal with all proj system.
Just a hint. Not sure
Francois.
I am writing again, because no one is giving me an answer, and i cannot
find
any documentation on the internet.
I am still trying, and hope to see a map from our wms server in
geonetwork/intermap.
When i am on this site (popup):
http://lv-ternan.fds.fo:8080/geonetwork/intermap/srv/fo/mapServers.listServers
To the right of "Map Server" I choose "- Other WMS server (specify below)"
and to the right of "Specify if other:" i write:
http://www.kagi.fo/cgi-bin/mapserv.exe?map=c:/heimasidur/Kagi/Data/peturkirkeUTM.map
Then i get a very nice screen with information about all the data
and layers, and everything looks fine so far. Then i choose some
layers, and push "OK" at the bottom. Than i get a nice screen where
the map should arrive, but the image isnt there - or, there is an
image, but only with the x at the top left
corner, that means it cannot show the image.
Do you know what i have done wrong ? Can i see the error message anywhere
Ce message a ete verifie par MailScanner pour des virus ou des polluriels
et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et privés.Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and private. Any total or partial publication, use or
distribution must be authorized.
et rien de suspect n'a ete trouve.
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
confidential and secret. Any total or partial publication, use or
