[GeoNetwork-devel] Re wms / intermap problem
sorry, i think i was too fast !!
We cannot use EPSG:4326 :frowning:
We need to use UTM zone 29N, WGS84 (epsg:32629), and this is very crucial to
us !
And epsg:32629 is not working :frowning:
Is there another solution ?
----- Original Message -----
From: "François-Xavier PRUNAYRE" <fx.prunayre@anonymised.com>
To: <peturkirke@anonymised.com>
Sent: Tuesday, November 07, 2006 7:05 PM
Subject: Re [GeoNetwork-devel] wms / intermap problem
Hi Petur, could you try to add the EPSG:4326 (WGS84) code to you mapfile
WEB / METADATA / "ows_srs" "EPSG:4326 EPSG:32629"
I'm not sure Intermap could deal with all proj system.
Just a hint. Not sure
Francois.
I am writing again, because no one is giving me an answer, and i cannot
find
any documentation on the internet.
I am still trying, and hope to see a map from our wms server in
geonetwork/intermap.
When i am on this site (popup):
http://lv-ternan.fds.fo:8080/geonetwork/intermap/srv/fo/mapServers.listServers
To the right of "Map Server" I choose "- Other WMS server (specify below)"
and to the right of "Specify if other:" i write:
http://www.kagi.fo/cgi-bin/mapserv.exe?map=c:/heimasidur/Kagi/Data/peturkirkeUTM.map
Then i get a very nice screen with information about all the data
and layers, and everything looks fine so far. Then i choose some
layers, and push "OK" at the bottom. Than i get a nice screen where
the map should arrive, but the image isnt there - or, there is an
image, but only with the x at the top left
corner, that means it cannot show the image.
Do you know what i have done wrong ? Can i see the error message anywhere
Ce message a ete verifie par MailScanner pour des virus ou des polluriels
et
rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et privés.Toute publication, utilisation ou diffusion, meme
partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal,
confidential and private. Any total or partial publication, use or
distribution must be authorized.
et rien de suspect n'a ete trouve.
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
confidential and secret. Any total or partial publication, use or
Petur, It depends what you want to do. Could you not use both in the service
? Then user will choose one projection system.
If you set in your mapfile
People who connect to your webservice will be able to choose between WGS and
UTM zone 29N.
If you provide only WEB / METADATA / "ows_srs" "EPSG:32629", some client
able to view only WGS84 will not be able to query your service.
Intermap need WGS84 (it looks that there is no reprojection capability in
Intermap - Stefano correct me if needed ?). But if other applications want
to display your data in UTM, It will be also available on your webservice.
In general, I think it's a good practice to allow at least WGS84 in your
WMS.
For more information on how to manage projection on you webservice (see
http://mapserver.gis.umn.edu/docs/howto/wms_server) and maybe move that
discussion to mapserver mailling list.
Cheers. Francois
-----Message d'origine-----
De : Petur Kirke [mailto:peturkirke@anonymised.com]
Envoyé : mercredi 8 novembre 2006 10:05
À : geonetwork-devel@lists.sourceforge.net
Cc : François-Xavier PRUNAYRE
Objet : Re: Re [GeoNetwork-devel] wms / intermap problem
us !
Francois.
find
rs
eUTM.map
et
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
Is there no plan to implement other projections like for example EPSG:32629
into InterMap ?
Or is there any possibility that you can implement it for us ???
From: "Jeroen Ticheler" <Jeroen.Ticheler@anonymised.com>
To: "Petur Kirke" <peturkirke@anonymised.com>
Cc: <geonetwork-devel@lists.sourceforge.net>; "François-Xavier PRUNAYRE"
Sent: Thursday, November 09, 2006 4:33 AM
Subject: Re: [GeoNetwork-devel] Re wms / intermap problem
Hi Petur,
This is a problem with respect to InterMap. We use 4326 as default
and we did not add the option to change the projection in the client.
However, adding the different EPSG codes to the map file will allow
other clients (most likely thick ones) of the services to request the
map in EPSG:32629 projection.
(I am not sure if 4326 is the mandatory and default WMS projection!?)
Ciao,
Jeroen
> crucial to
> us !
>> mapfile
>> Francois.
>> cannot
> find
>> below)"
> peturkirkeUTM.map
>> anywhere
>> polluriels
> et
>> personnels,
>> diffusion, meme
>> personal,
>> polluriels
>> personnels,
> diffusion, meme
>> personal,
> Using Tomcat but need to do more? Need to support web services,
> security?
> Get stuff done quickly with pre-integrated technology to make your
> job easier
> Download IBM WebSphere Application Server v.1.0.1 based on Apache
> Geronimo
> http://sel.as-us.falkag.net/sel?
> cmd=lnk&kid=120709&bid=263057&dat=121642
> GeoNetwork-devel mailing list
> GeoNetwork-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
> GeoNetwork OpenSource is maintained at http://sourceforge.net/
> projects/geonetwork
Is there any plans to add the option to change the projection in the
InterMap client ?
Hi Petur,
Ciao,
Jeroen
> crucial to
> us !
>> mapfile
>> Francois.
>> cannot
> find
>> below)"
> peturkirkeUTM.map
>> anywhere
>> polluriels
> et
>> personnels,
>> diffusion, meme
>> personal,
>> polluriels
>> personnels,
> diffusion, meme
>> personal,
> security?
> job easier
> Geronimo
> projects/geonetwork
