[GeoNetwork-devel] readwriteUuid usage on metadata creation
Hi list,
I'm dealing with a plugged schema which has a non-standard metadata identifier;
it means it's not an UUID, but has to be somehow "processed".
As already suggested by Francois, I'm using the update-fixed-info xsl to
perform this task, in a schema which defines
<readwriteUuid>true</readwriteUuid> in its schema-ident.
It works nicely when updating a metadata, but, when the metadata is first
created, the UUID which is reported to the persistence logic is still the
automatic generated UUID.
It means that, just after creating the new metadata, inside the persisted XML
metadata I get the correct fileIdentifier generated by the update-fixed-info, and
in the data.uuid DB field I have the new UUID generated by GN, which is wrong.
The data.uuid value is properly set only after the first save/update.
I guess that in DataManager.createMetadata(...), after calling the
updateFixedInfo(...), something similar to these lines
        if (schemaMan.getSchema(schema).isReadwriteUUID()) {
            uuid = extractUUID(schema, md);
(copied from updateMetadata()) should be added.
Do you see any drawback in this fix?
   Ciao,
   Emanuele
== *GeoSolutions will be closed for seasonal holidays from 23/12/2013 to
06/01/2014* ==
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Hi Emanuele,
I personnaly don’t see any drawback to this.
IMO, if the uuid has been changed by the updateFixedInfo, then the uuid DB field should be updated as well.
This should also be the case on a metadata insert.
I’m having same kind of issue on a metadata insert.
  1. Your fix should be applied too
  2. There is a boolean in the insert method to decide if we call updateFixedInfo method or not.
    https://github.com/geonetwork/core-geonetwork/blob/develop/core/src/main/java/org/fao/geonet/kernel/DataManager.java#L1385
I don’t understand why this boolean is set to false in the case of an import :
https://github.com/geonetwork/core-geonetwork/blob/develop/core/src/main/java/org/fao/geonet/kernel/mef/Importer.java#L531
Any reason why this is false ?
Should be true because in the case where the uuid is modified, this causes some issues.
On Fri, Dec 20, 2013 at 3:42 PM, Emanuele Tajariol <etj@anonymised.com> wrote:
Hi list,
I’m dealing with a plugged schema which has a non-standard metadata identifier;
it means it’s not an UUID, but has to be somehow “processed”.
As already suggested by Francois, I’m using the update-fixed-info xsl to
true in its schema-ident.
I guess that in DataManager.createMetadata(…), after calling the
updateFixedInfo(…), something similar to these lines
Ciao,
Emanuele
== GeoSolutions will be closed for seasonal holidays from 23/12/2013 to
06/01/2014
Technical Lead
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don’t have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349831&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Florent Gravin
Camptocamp - Chambéry
0479444492
2014/1/2 Florent Gravin <florent.gravin@anonymised.com>
Hi Emanuele,
I think mainly because MEF is supposed to restore a catalog backup as it was (no changes on datestamp, nor uuid, …).
But in case a profile allows uuid modification, it sounds relevant to apply the updateFixedInfo or at least a step which takes care of uuid update/synch. I see 3 options:
  1. add a parameter in the import page to apply updateFixedInfo
  2. apply updateFixedInfo for profile with read/write uuid
  3. create a step to update/synch uuid only (to not alter dateStamp, …)
Anyway, if a record in a specific profile allowing read/write uuid, the uuid should remain the same after updateFixedInfo in most of (all) the cases. It may only change if a) the uuid is computed by a rule which change (should not happen as far as the profile is specified) or b) the uuid is based on some other field in the metadata record and the uuid is not in synch with those fields.
Cheers.
Francois
Hi list,
Ciao,
Emanuele
06/01/2014
Technical Lead
Florent Gravin
0479444492
Hi Florent and Francois,
Alle 08:39:44 di Friday 3 January 2014, Francois Prunayre ha scritto:
> Hi Emanuele,
> I personnaly don't see any drawback to this.
> I'm having same kind of issue on a metadata insert.
> I don't understand why this boolean is set to false in the case of an
> import :
was (no changes on datestamp, nor uuid, ...).
> causes some issues.
1) add a parameter in the import page to apply updateFixedInfo
2) apply updateFixedInfo for profile with read/write uuid
3) create a step to update/synch uuid only (to not alter dateStamp, ...)
Please note that you are talking about 2 different issues:
- when the updateFixedInfo should be called
- when/if the UUID on DB should be updated.
In my specific case, the updateFixedInfo is properly called on metadata
creation.
What is not done, is the porting of the new generated fileIdentifier as the
metadata uuid in the DB, thus breaking the alignment between them.
(As reported in a previous email, the alignment is corrected as soon as the
metadata is updated.)
My proposed fix would only set the modified UUID if the profile has a read/write
uuid.
In the profile I'm working on, the requirements are about inserting a fixed
string as a prefix in the UUID. Of course this is needed only once when
creating the metadata record.
In this case the UUID should not be replaced when importing MEF.
   Emanuele
solutions.it>wrote:
>> Hi list,
>> identifier;
>> first created, the UUID which is reported to the persistence logic is
>> still the automatic generated UUID.
>> persisted XML
>> wrong.
>> Ciao,
>> Emanuele
Our support, Your Success!
Visit http://opensdi.geo-solutions.it for more information.
Technical Lead
