Hi
I’m working in a project based on master and when rebuilding the index I get this bizarre error in log file:
org.apache.lucene.facet.taxonomy.InconsistentTaxonomyException: Taxonomy was recreated at: 1361183021364638000 != 1360937230438373000
at org.apache.lucene.facet.taxonomy.directory.DirectoryTaxonomyReader.refresh(DirectoryTaxonomyReader.java:364)
at org.fao.geonet.kernel.search.LuceneIndexReaderFactory.maybeReopen(LuceneIndexReaderFactory.java:226)
at org.fao.geonet.kernel.search.LuceneIndexReaderFactory.getReader(LuceneIndexReaderFactory.java:71)
at org.fao.geonet.kernel.search.SearchManager.getIndexReader(SearchManager.java:1326)
at org.fao.geonet.kernel.search.SearchManager.getDocsChangeDate(SearchManager.java:1040)
The error happens in the method maybeReopen of LuceneIndexReaderFactory getTaxonomyReader().refresh();
I see it also in log after searches are done.
My project is not using latest master, so not sure if upgrading will solve it, but can’t manage to upgrade for now. Any tip on what can cause the error is very welcome.
Thanks and regards,
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
