Hi Francois,
Happy New Year!
On Jan 8, 2007, at 7:54 AM, François Prunayre wrote:
Hi Jeroen (and Patrizia), coming back to you regarding a spatial reference
system list. Did you choose a way to include one in your stand alone editor
No, there's no special way of handling those. Something for the future.
I started adding functionnality from the project in France to Geonetwork. My
first job was on the thesaurus side (see mailing list). For january, I
expect to spend some more time (3-4 days) to make the thesaurus integration
better according to comments I will have on the mailing list.Later on, I expect to add other functionnalities which could be useful for
everyone (Contact directory, SRS list, new search criteria ?, French profil
?, ...). Maybe we could exchange on that to fix priority according to your
plan for the next release... maybe during february.
Roberto is currently adding so-called sub-templates to the editor. The principle is that small parts of a metadata record, for example a contact, can be stored in the catalog. The editor offers a drop down list at locations that have sub-templates available so the editor can choose the template he needs in that location. This will copy the content of the sub template into the metadata.
The functionality will be available by the time of the beta 1 release.
For your contact directory this would/could mean that it makes most sense to store contacts, SRS's etc as small XML sub-templates in the catalog. I would not like to see separate tables or so to store the same information
For the future, the handling of specific sub-templates in the editor may be improved on a case-by-case basis to for instance allow a user to search for a sub-template through a query interface. This is something that Roberto has also been working on in a slightly different context and that might be of interest.
Another unsolved issue here is the updating of a sub-template and how that is reflected in the metadata that uses a sub-template already Maybe a URI should be stored in the XML record in the places that use a sub-template!?
Ciao,
Jeroen
Regards. Francois
-----Message d'origine-----
De : Ticheler Jeroen [mailto:jeroen.ticheler@…124…]
Envoyé : mercredi 18 octobre 2006 12:58
À : François Prunayre
Cc : Patrizia (SDRN) Monteduro
Objet : Reference system databaseHi Francois,
We are working on a stand alone metadata editor and run into the spatial
reference system troubleI know you are working on some plug in for
GeoNetwork to deal with those!? Do you have a database that we could use to
also include in the stand alone editor? How do you plan to deal with it?
Have the user select from a huge drop down list?
Ciao,
Jeroen
