[GeoNetwork-devel] Reference to old SVN repo in main pom.xml
Hi
In the main pom.xml it’s used the SCM maven plugin, but it’s still referenced the old SVN repository in SourceForge (similar for issue tracking).
See https://github.com/geonetwork/core-geonetwork/blob/develop/pom.xml#L16
Not sure if its really used this maven plugin?
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
To the best of my knowledge that plugin has never really been used.
On Mon, Jun 23, 2014 at 9:04 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
GeoNetwork-devel mailing list
Hi
In the main pom.xml it's used the SCM maven plugin, but it's still
tracking).
Jose García
I think that scm is more informative than a real plugin. But yes, it would
be good to change it.
María.
Ok, thanks will update it then.
On Mon, Jun 23, 2014 at 9:06 AM, María Arias de Reyna <delawen@anonymised.com> wrote:
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi
Jose García
I think that scm is more informative than a real plugin. But yes, it would be good to change it.
María.
IIRC, it can be used by some extra plugins (related to reporting), in order
to autogenerate a changelog for example:
http://maven.apache.org/plugins/maven-changelog-plugin/
Pierre Mauduit
Ingénieur développement
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 58 02
Fax : 04 79 70 15 81
Mail : pierre.mauduit@anonymised.com <yves.jacolin@anonymised.com>
http://www.camptocamp.com
