!!Note that THIS IS AN UNSTABLE VERSION for testing and that it should not be used in an operational environment!!
Dear all,You can now download and test the first release candidate (v2.8.0RC1) of GeoNetwork opensource version 2.8.0 from SourceForge.net:
We did not generate a dedicated Windows installer, but this multiplatform installer should also work on Windows systems.
You can find a list of new functionality in v2.8.0 at http://trac.osgeo.org/geonetwork/wiki/proposals#a2.7.0release (ignore the 2.7.0 - that is referring to the development version and has all been included in the 2.8.0 release) as well as in the documentation included in the installer.
A list of fixes and changes in 2.8.0 RC1 can be found at the bottom of this email.
If you have any fixed or improvements you want to contribute back, the best is to use git to get a local copy of the source code, apply the fix and put out a Pull request so your improvements can be integrated quickly. Otherwise you can also create new Tickets in the http://trac.osgeo.org/geonetwork issue tracker.
Looking forward to your testing, feedback and contributions. The next (and last) Release Candidate (v2.8.0RC2) is planned in about two weeks.
Happy testing,
Jeroen
Chair of the PSC of GeoNetwork opensource
=== GeoNetwork 2.8.0RC1: List of changes
— Bug fixes
- #519 A valid record gets broken by editing
- #662 Can’t initiate search using the ENTER key
- #905 Outdated / Invalid links
- #932 New line issue with Oracle scripts
- #950 Thumbnail overview not working on iso19139 schema
- #957 gmd:PT_Locale@anonymised.com changed without changing gmd:LocalisedCharacterString@anonymised.com.
- #960 Open for edit a ISO19139-mcp1.4 record resets start/end date to 1970-01-01
- #964 Catalan translation for version subsequent to 2.6.4
- #967 Security: GN vulnerable to XML bombs
- #968 Start versioning does not version all files for the initial version.
- #969 Metadata versioning creates version of files even if not changed
- #972 New UI: Groups combobox preserves old values when login with a different user
- #974 Harvesting missing after migration
- #977 Server startup stalls when thesaurus tries to rebuild from register record(s) with xlinks
- #981 Privileges and categories not set when using OAI-PMH harvester
- #982 Local thesauri (ie. created in GN thesaurus manager) do not have a title field
- #983 geopublisher leaks geoserver user/pass credentials to users with editor profile
- #986 ext-lang-*.js not found due to 3 char ISO 639-2 - should use 2 char.
- #1003 Widgets / Create metadata window improvements
- #1005 Search suggestion / invalid JSON if field contains "
- #1008 Widgets / download and dynamic record info not available
- #1010 Privileges not set when using CSW harvester
- #1033 Widgets / username field / browser does not remember previous values
- #1038 CSV export / quoted field, escape " and newline in text
- #1044 Harvester / CSW / OperationAbortedEx(“No GET (using CQL) or POST (using FE) DCP available in this service.”).
- #1060 Statistics / images not display
- #1063 schemaplugin has schemaLocation/noNamespaceSchemaLocation but not available to update-fixed-info.xsl
- Added some missing ext js locales (CA, RU, PT, CN, FI and NO) that seems to be missing - This corrects the calendar so that the proper language is displayed.
- Add full url for thumbnails, put ‘eng’ in full url for thumbnail
- Full Url thumbnail : add baseUrl to thumbnail url instead of hardcoded /geonetwork
- Fix issue with OAI-PMH harvester not updating icons correctly
- Fix null pointer exception when harvesting from a WMS server with non-requestable category layers (i.e. layers without a name element)
- Fix issue with privileges and categories not being set on harvested WxS resources and services
- Fixes in spatial filters creation
- Fix disk deletion of thumbnail and gui bug of thumbnail widget form
- Fix to make superBrief more general for those profiles that deine their own CI_Citation
- Fix capabilities xml docs to validate
- Fix IE8 JS errors
- Fix rating widget initialization.
- For subtemplates, use the computed title instead of the title column by default (fix the subtemplate title name in search results).
- Fix subtemplate search (search form panel toolbar field not take into account).
- Fix generation of schema location URL (used when a schemalocation is not specified in schema-ident.xml)
- Look across all ISO profiles to allow thesaurus type to be chosen from a profile as well as base standard
- Remove dependencies not permitted under licensing rules
- Remove schema location from dublin-core - forces schema location to be generated using GeoNetwork schema.xsd ie. <geonetwork_url>/xml/schemas/dublin-core/schema.xsd
- Reset search form and results when clicking reset. Display info panel.
— Changes
- #550 No Portuguese translation for ISO19110
- #973 New Category - Physical samples
- #1045 Turkish translation
- Add ‘_groupPublished’ in Lucene index corresponding on all group name the MD is refered to
- Add siteUrl as parameter to xslts called by wfs getfeature harvester. Allows these xslts to query the local geonetwork catalog for things like
register definitions etc. - Changed …/…/ to {/root/gui/url} where appropriate for consistency as it is follows the same format as the others.
- Update instructions for controlling spatial index transactions
**GeoCat** introduces Bridge© An extension to ArcGIS© to instantly publish data and metadata on GeoServer and GeoNetwork. See [http://geocat.net](http://geocat.net/) for more details. Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
Tel: +31 (0)6 81286572
http://geocat.net
Please consider the environment before printing this email.
