[GeoNetwork-devel] Release Candidate v2.10.0RC1 now available for testing
Dear all,
I have downloaded the last candidate release and problems with metadata
harvesting persist. I have tried to harvest wms service from local
geoserver, limiting CRS list, and it don't work.
I have only load iso19139 template, is needed other metadata template,
perhaps?
Miguel A. Manso
El 03/05/2013 16:47, Francois Prunayre escribió:
Dear all, You can now download and test the release candidate
(v2.10.0RC1) of GeoNetwork opensource:
https://sourceforge.net/projects/geonetwork/files/GeoNetwork_unstable_development_versions/2.10.0RC1/
The installer is multiplatform and also work on Windows systems.
You can find a list of new functionality at
http://trac.osgeo.org/geonetwork/wiki/proposals/release2.10.0
and a list of fixes and changes at
https://raw.github.com/geonetwork/core-doc-sources/2.10.x/changes2.10.x.txt
If you have any fixed or improvements you want to contribute back, the
best is to use git to get a local copy of the source code, apply the
fix and put out a Pull Request so your improvements can be integrated
quickly. Otherwise you can also create new Tickets in the issue
tracker (http://trac.osgeo.org/geonetwork).
Looking forward to your testing, feedback and contributions.
The release of GeoNetwork opensource v2.10.0 stable is planned for end of May.
Thanks to all developers and contributors! Happy testing,
Francois
Get 100% visibility into Java/.NET code with AppDynamics Lite
It's a free troubleshooting tool designed for production
Get down to code-level detail for bottlenecks, with <2% overhead.
Download for free and get started troubleshooting in minutes.
http://p.sf.net/sfu/appdyn_d2d_ap2
GeoNetwork-devel mailing list
2013/5/6 Miguel-Angel Manso-Callejo (UPM) <m.manso@anonymised.com>:
Dear all,
Could you provide more details on the harvester configuration ?
Any messages in the log ?
perhaps?
Templates are not required to use OGC WxS harvesting.
Cheers.
Francois
Miguel A. Manso
Francois
Introducing AppDynamics Lite, a free troubleshooting tool for Java/.NET
Get 100% visibility into your production application - at no cost.
Code-level diagnostics for performance bottlenecks with <2% overhead
http://p.sf.net/sfu/appdyn_d2d_ap1
