Oops, the HTML generated for the
"front page" (main.home) contains
the tags <mainpage1> and <mainpage2>.
(Bring up the top-level page in your
browser, use the browser's "View Source"
and search for "mainpage".)
[Hmm, what format is the generated HTML
supposed to be, anyway? It isn't
any of HTML 3, HTML 4, XHTML 1.0, . . .
Would be good to generate HTML that
passes through the W3C's validator.]
Patch attached.
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
(attachments)
gnpatch4.txt (834 Bytes)
Patch attached.
Oops (but this time, my fault) . . .
the patch I just sent happens to
work for the current settings of mainpage1
and mainpage2 but not in general. Please
use this patch instead.
Richard Walker
(attachments)
gnpatch5.txt (844 Bytes)
Thanks! Merged it into trunk and branch.
Jeroen
Patch attached.
-- Richard Walker
Index: web/geonetwork/xsl/main-page.xsl
--- web/geonetwork/xsl/main-page.xsl (revision 1209)
+++ web/geonetwork/xsl/main-page.xsl (working copy)
@@ -289,9 +289,9 @@
<tr>
<td>
<xsl:comment>MAINPAGE 1</xsl:comment>
- <xsl:copy-of select="/root/gui/strings/mainpage1"/>
+ <xsl:copy-of select="/root/gui/strings/mainpage1/node()"/>
<xsl:comment>MAINPAGE 2</xsl:comment>
- <xsl:copy-of select="/root/gui/strings/mainpage2"/> <a href="mailto:{/root/gui/env/feedback/email}">
+ <xsl:copy-of select="/root/gui/strings/mainpage2/node()"/> <a href="mailto:{/root/gui/env/feedback/email}">
<xsl:value-of select="/root/gui/env/feedback/email"/>
</a>
</td>
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
GeoNetwork-devel mailing list
Indeed it would be - seems that the different browsers fall back to odd things when they get html they don't understand - this would explain some of the differences in behaviour between GN in exploder and firefox - exploder seems less tolerant/more sensitive to problems and can do funny things like not render content from further down the page etc! Very annoying and sometimes hard to find
especially with (more) javascript thrown into the mix!
Simon
Yes, I had this problem this afternoon.
I've been experimenting with having Jeeves
generate XHTML. So far so good, but
I just tried adding the first bit
of JavaScript and IE7 gave me a blank
page.
It seems even IE7 does not parse XHTML correctly.
You can't send it <script ... /> tags;
you have to write .
Because XSLT will optimize the latter to
the former when you're outputting XML,
you have to write something like
<script ...>//</script> in your XSLT script.
I found this out from Googling; I got
help from a page written in 2005 . . . sigh.
Richard Walker
One way to handle this is to put javascript element content inside a CDATA section, see http://www.rikkertkoppes.com/thoughts/common-xhtml-problems/ for example. But I think it’s awkward in any case… XHTML doesn’t support IFRAMEs and the most popular browser in the world Internet Explore will not handle it if you serve it with mime-type application/xhtml+xml, as you’re supposed to do. I vote for HTML 4 strict.
Another thing, may it be a nice idea to state which browser versions are “officially” supported by GeoNetwork ?
regards
heikki doeleman
On Thu, Apr 24, 2008 at 9:45 AM, Software Improvements gn-devel <gn-devel@anonymised.com> wrote:
things when they get html they don’t understand - this would explain
I’ve been experimenting with having Jeeves
page.
You can’t send it <script … /> tags;
you have to write .
the former when you’re outputting XML,
Richard Walker
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don’t miss this year’s exciting event. There’s still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
Inventions cannot, in nature, be a subject of property. – Thomas Jefferson
you have to write .
Oops, my tags got stripped by the mailing
list! After the text
"you have to write" I wrote a script begin tag
immediately followed by a script end tag.
Richard Walker
heikki wrote:
One way to handle this is to put javascript element content inside a CDATA section, see http://www.rikkertkoppes.com/thoughts/common-xhtml-problems/ for example. But I think it's awkward in any case.. XHTML doesn't support IFRAMEs and the most popular browser in the world Internet Explore will not handle it if you serve it with mime-type application/xhtml+xml, as you're supposed to do. I vote for HTML 4 strict.
Thanks for the link - this confirms what I've been finding
out.
Richard Walker
