[GeoNetwork-devel] Removing Jeeves ScheduleManager ?
Hi all, is anyone using Jeeves schedule manager [1] which could be configured in config.xml [2] ? It’s a pretty old feature to schedule harvesters by XML configuration I think but I’ve never seen user using it and the usage is not documented as far as know.
So, I would like to propose to remove it for 2 main reasons:
  1. in some setup in multinodes config, the app consumes lots of threads (mainly related to Quartz schedulers and workers) - so removing this feature decrease the number of threads required
  2. cleaning the codebase
What do you think ?
Francois
[1] https://github.com/geonetwork/core-geonetwork/blob/develop/jeeves/src/main/java/jeeves/server/ScheduleManager.java
[2] https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/config.xml#L123
On Mon, Jul 28, 2014 at 11:14 AM, Francois Prunayre <fx.prunayre@anonymised.com>
configured in config.xml [2] ? It's a pretty old feature to schedule
harvesters by XML configuration I think but I've never seen user using it
1) in some setup in multinodes config, the app consumes lots of threads
2) cleaning the codebase
What do you think ?
Francois
[1]
[2]
From my part, you can remove it. If we need to configure harvesters by
configuration files in the future, I am sure we can find a more optimized
way to do this.
María.
2014-07-28 11:20 GMT+02:00 María Arias de Reyna <delawen@anonymised.com>:
What do you think ?
Francois
[1]
[2]
way to do this.
Yep, i agree. It could be nice to be able to copy/paste harvester
configuration from one node to another so users can exchange configs (and
also provide config when reporting bug).
Thanks for your feedback Maria.
Francois
María.
I do use it but I think it is ok to remove because I can easily do the scheduling with spring.
On Mon, Jul 28, 2014 at 11:24 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Infragistics Professional
Build stunning WinForms apps today!
Reboot your WinForms applications with our WinForms controls.
Build a bridge from your legacy apps to the future.
http://pubads.g.doubleclick.net/gampad/clk?id=153845071&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
Yep, i agree. It could be nice to be able to copy/paste harvester configuration from one node to another so users can exchange configs (and also provide config when reporting bug).
Francois
On Mon, Jul 28, 2014 at 11:14 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
What do you think ?
Francois
From my part, you can remove it. If we need to configure harvesters by configuration files in the future, I am sure we can find a more optimized way to do this.
María.
2014-07-28 11:56 GMT+02:00 Jesse Eichar <jesse.eichar@anonymised.com>:
Ok so we can keep it. I'll only turn it off in my multinode setup.
Thanks.
Francois
What do you think ?
Francois
[1]
[2]
way to do this.
Francois
María.
