[GeoNetwork-devel] REPEATED CFV : Clustering GeoNetwork
dear PSC,
this probably has escaped your attention, or for other reasons you haven’t voted.
Meanwhile we have discussed this proposal privately with François and Jesse; created a fully functional test cluster; updated the proposal page; and added a patch to the proposal.
Thanks for your prompt votes,
Heikki Doeleman & Jose García
On Thu, Mar 22, 2012 at 4:37 PM, heikki <tropicano@anonymised.com> wrote:
dear PSC,
please vote on our proposal to make it possible to load-balance GeoNetwork : http://trac.osgeo.org/geonetwork/wiki/LoadBalanceable.
thanks for your prompt responses,
kind regards
Heikki,
I have a question about the XLINK cache (in JCS) - should the cache be in the messaging system? Reason is that the cache should be consistent across the nodes otherwise its possible you might receive a different metadata record depending on which node you get the record from as the information in the XLINK reference may have changed (its not always tied to an indexing event).
Simon
________________________________________
Sent: Friday, 13 April 2012 10:55 PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] REPEATED CFV : Clustering GeoNetwork
dear PSC,
this probably has escaped your attention, or for other reasons you haven't voted.
On Thu, Mar 22, 2012 at 4:37 PM, heikki <tropicano@anonymised.com<mailto:tropicano@anonymised.com>> wrote:
dear PSC,
please vote on our proposal to make it possible to load-balance GeoNetwork : LoadBalanceable – GeoNetwork opensource Developer website.
kind regards
Hi Simon
I think so, any cache used should be synchronized using the messaging. We’ll check to update the code.
Thanks for pointing it.
Jose García
On Fri, Apr 13, 2012 at 6:34 PM, Simon.Pigot@anonymised.com wrote:
Heikki,
Simon
dear PSC,
On Thu, Mar 22, 2012 at 4:37 PM, heikki <tropicano@anonymised.commailto:[tropicano@anonymised.com](mailto:tropicano@anonymised.com)> wrote:
dear PSC,
kind regards
For Developers, A Lot Can Happen In A Second.
Boundary is the first to Know…and Tell You.
Monitor Your Applications in Ultra-Fine Resolution. Try it FREE!
http://p.sf.net/sfu/Boundary-d2dvs2
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Thanks for the patch Heikki, but it looks like there is some issues in it:
* org.fao.geonet.jms package is not in ?
* the patch looks to rollback many changes made last week on trunk.
Some examples:
* metadata-status.xsl
* +++ web/src/main/java/org/fao/geonet/kernel/Schema.java (working
copy) remove dependElements
* +++ web/src/main/java/org/fao/geonet/kernel/SchemaManager.java (working
copy) remove some Javadoc
* + <param name="query" value="SELECT * FROM Groups WHERE internal =
'n ' ORDER BY name" />
sould be
'n' ORDER BY name" />
maybe ?
* Maybe it's better to use Logger instead of:
System.out.println("\n\n\n\n\n** initialize\n\n\n\n");
System.err.println(x.getMessage());
System.out.println("calculating groupdir for md with id: '" + id + "'");
to keep all message to log file
About synchronization, maybe you should take care of schema loaded by
a node, maybe others should receive a message too to reload schemas ?
Cheers.
Francois
PS : I uploaded the patch removing some of the unrelated sections to
load balancing to make it easier to read.
Le 13 avril 2012 18:42, Jose Garcia <jose.garcia@anonymised.com> a écrit :
Hi Simon
I think so, any cache used should be synchronized using the messaging. We'll
Jose García
On Fri, Apr 13, 2012 at 6:34 PM, <Simon.Pigot@anonymised.com> wrote:
Heikki,
event).
Simon
dear PSC,
voted.
dear PSC,
kind regards
Boundary is the first to Know...and Tell You.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
