[GeoNetwork-devel] repository and line normalization
Hi, I recently switched from a Mac to a windows machine and found that as soon as I checked out core-geonetwork there were several complaints about line endings.
I looked through the help on Github and came up with a page explaining the steps to take for line-normalization. They looked simple and in fact when I tried them out it seemed only a few files were affected so I committed the changes.
Since then Maria and Francois have reported problems on their Linux machines with line endings. So I installed Linux Mint and did a clone. I have played with that install and clone and have had no problems. But Francois has continued to have issues.
I would like people on Macs and Linux who have this problem to first try making a clean clone of the repository and if they still have line-ending problems to let me know which files they are and how many.
Likely we will have to commit some of these files but we need to try to keep them to a minimum for merging.
Tip: If you have merge problems try:
git merge -s ignore-all-space
Jesse
On Tue, Mar 26, 2013 at 7:54 AM, Jesse Eichar
line endings.
changes.
Jesse
Own the Future-Intel&reg; Level Up Game Demo Contest 2013
Rise to greatness in Intel's independent game demo contest.
Compete for recognition, cash, and the chance to get your game
on Steam. $5K grand prize plus 10 genre and skill prizes.
Submit your demo by 6/6/13. http://p.sf.net/sfu/intel_levelupd2d
GeoNetwork-devel mailing list
I tried on a new Ubuntu 12.04 and this is the result (very long). It
doesn't matter if I try to reset hard or checkout the files, the
problem is there:
root@anonymised.com /tmp # git clone
git://github.com/geonetwork/core-geonetwork.git test
Cloning into 'test'...
remote: Counting objects: 75264, done.
remote: Compressing objects: 100% (25620/25620), done.
remote: Total 75264 (delta 45595), reused 73605 (delta 44287)
Receiving objects: 100% (75264/75264), 112.02 MiB | 23.91 MiB/s, done.
Resolving deltas: 100% (45595/45595), done.
root@anonymised.com /tmp # cd test
root@anonymised.com /tmp/test # git status
# On branch master
# Changes not staged for commit:
# (use "git add <file>..." to update what will be committed)
# (use "git checkout -- <file>..." to discard changes in working
directory)
# modified:
cachingxslt/src/main/java/de/fzi/dbs/xml/transform/CachingTransformerFactory.java
# modified: cswtest/TEST-org.fao.geonet.csw.TestCswIsoApp.xml
# modified:
jeeves/src/main/java/jeeves/utils/TransformerFactoryFactory.java
# modified:
oaipmh/src/main/java/org/fao/oaipmh/requests/TokenListRequest.java
# modified:
sde/src/main/java/com/esri/sde/sdk/GeoToolsDummyAPI.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SDEPoint.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeColumnDefinition.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeConnection.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeCoordinateReference.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDBMSInfo.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDBTune.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDefs.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDelete.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDoesNotExistException.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeError.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeException.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeExtent.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeFilter.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeInsert.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeInstance.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeLayer.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeObjectId.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeQuery.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeQueryInfo.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRaster.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterAttr.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterBand.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterColumn.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterConstraint.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterConsumer.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterProducer.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterRenderedImage.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterScanLineGenerator.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterScanLineProducer.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterTile.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRegistration.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRelease.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeRow.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeServerObj.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeShape.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeShapeFilter.java
# modified:
sde/src/main/java/com/esri/sde/sdk/client/SeSqlConstruct.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeState.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeStreamOp.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeTable.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeUpdate.java
# modified: sde/src/main/java/com/esri/sde/sdk/client/SeVersion.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/EmptyType.java
# modified:
sde/src/main/java/com/esri/sde/sdk/pe/PeCoordinateSystem.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/PeFactory.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/PePCSDefs.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/PeParameters.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/PeProjectedCS.java
# modified:
sde/src/main/java/com/esri/sde/sdk/pe/PeProjectionException.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/PeUnit.java
# modified: sde/src/main/java/com/esri/sde/sdk/pe/PeUnitsDefs.java
# modified: web-client/src/main/resources/apps/css/gnmapdefault.css
# modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/FeatureRecord.js
# modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/LayerRecord.js
# modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/LayerStore.js
# modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/ScaleStore.js
# modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/widgets/Action.js
# modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/widgets/LegendImage.js
# modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/form/GeometryMapField.js
# modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/lang/de.js
# modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/CategoryView.js
# modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/FacetsPanel.js
# modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/editor/EditorTools.js
# modified:
web-client/src/main/resources/apps/js/OpenLayers/lib/OpenLayers/Format/WMSCapabilities/v1_3.js
# modified:
web-client/src/main/resources/apps/js/OpenLayers/lib/OpenLayers/Format/WMSCapabilities/v1_3_0.js
# modified:
web-client/src/main/resources/apps/js/ext/ext-all-debug-w-comments.js
# modified: web-client/src/main/resources/apps/js/ext/ext-all-debug.js
# modified:
web-client/src/main/resources/apps/js/ext/pkgs/cmp-foundation-debug.js
# modified:
web/src/main/java/org/fao/geonet/arcgis/ArcSDEConnection.java
# modified:
web/src/main/java/org/fao/geonet/arcgis/ArcSDEMetadataAdapter.java
# modified:
web/src/main/java/org/fao/geonet/csw/common/ConstraintLanguage.java
# modified:
web/src/main/java/org/fao/geonet/csw/common/CswOperation.java
# modified:
web/src/main/java/org/fao/geonet/csw/common/ElementSetName.java
# modified:
web/src/main/java/org/fao/geonet/csw/common/OutputFormatPreference.java
# modified:
web/src/main/java/org/fao/geonet/csw/common/OutputSchema.java
# modified:
web/src/main/java/org/fao/geonet/csw/common/OutputSchemaPreference.java
# modified: web/src/main/java/org/fao/geonet/csw/common/Section.java
# modified: web/src/main/java/org/fao/geonet/csw/common/TypeName.java
# modified: web/src/main/java/org/fao/geonet/csw/common/util/Xml.java
# modified:
web/src/main/java/org/fao/geonet/exceptions/UnAuthorizedException.java
# modified:
web/src/main/java/org/fao/geonet/guiservices/metadata/Sitemap.java
# modified: web/src/main/java/org/fao/geonet/kernel/KeywordBean.java
# modified:
web/src/main/java/org/fao/geonet/kernel/MetadataIndexerProcessor.java
# modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEHarvester.java
# modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEParams.java
# modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/localfilesystem/LocalFilesystemHarvester.java
# modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/localfilesystem/LocalFilesystemParams.java
# modified:
web/src/main/java/org/fao/geonet/kernel/oaipmh/ResumptionTokenCache.java
# modified:
web/src/main/java/org/fao/geonet/kernel/oaipmh/services/AbstractTokenLister.java
# modified:
web/src/main/java/org/fao/geonet/kernel/search/GeoNetworkAnalyzer.java
# modified:
web/src/main/java/org/fao/geonet/kernel/search/LuceneIndexField.java
# modified:
web/src/main/java/org/fao/geonet/kernel/search/LuceneQueryBuilder.java
# modified:
web/src/main/java/org/fao/geonet/kernel/search/LuceneUtils.java
# modified:
web/src/main/java/org/fao/geonet/kernel/search/StopwordFileParser.java
# modified:
web/src/main/java/org/fao/geonet/services/metadata/BatchOpsMetadataReindexer.java
# modified:
web/src/main/java/org/fao/geonet/services/notifications/domain/NotificationTarget.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/Activate.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/AddElement.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/Clear.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/DeleteElement.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/Download.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/EditElement.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetKeywordById.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetKeywords.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetList.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetNarrowerBroader.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetSelectedKeywords.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/List.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/SelectKeywords.java
# modified:
web/src/main/java/org/fao/geonet/services/thesaurus/UpdateElement.java
# modified:
web/src/main/java/org/fao/geonet/services/util/ServiceMetadataReindexer.java
# modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUArgumentParseException.java
# modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUDiag.java
# modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUParamTestDBO.java
# modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUParamTester.java
# modified: web/src/main/java/org/fao/geonet/util/HeapSorter.java
# modified:
web/src/main/java/org/fao/geonet/util/XMLExtensionFilenameFilter.java
# modified: web/src/main/java/org/fao/geonet/util/ZipUtil.java
# modified: web/src/main/webResources/WEB-INF/server.prop
# modified: web/src/main/webapp/WEB-INF/classes/JZKitConfig.xml.tem
# modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_abstract_expand.xsl
# modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_dsdl_include.xsl
# modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_schematron_message_xslt2.xsl
# modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_schematron_skeleton_for_saxon.xsl
# modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_svrl_for_xslt2.xsl
# modified: web/src/main/webapp/WEB-INF/classes/schematron/readme.txt
# modified:
web/src/main/webapp/WEB-INF/classes/schematron/sch-messages-ger.xhtml
# modified:
web/src/main/webapp/WEB-INF/classes/setup/sql/data/loc-pol-default.sql
# modified:
web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v280/loc-pol-default.sql
# modified:
web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v280/loc-rus-default.sql
# modified:
web/src/main/webapp/WEB-INF/data/config/codelist/external/thesauri/place/regions.rdf
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/dublin-core/loc/tur/labels.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/fgdc-std/templates/metadata.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/loc/nor/codelists.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/loc/nor/labels.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/present/csw/ogc-brief.xsl
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/present/csw/ogc-full.xsl
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/present/csw/ogc-summary.xsl
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/update-fixed-info.xsl
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/convert/ThreddsDIFToISO/DIFToISO.xsl
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/convert/thesaurus-transformation.xsl
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/loc/fre/codelists.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gco/gcoBase.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/basicTypes.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/coordinateOperations.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/coordinateReferenceSystems.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/coordinateSystems.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/dictionary.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/direction.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/geometryAggregates.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/geometryBasic2d.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/geometryComplexes.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/gml.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/gmlBase.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/grids.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/measures.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/readme.txt
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/referenceSystems.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/temporalTopology.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/topology.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/units.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/valueObjects.xsd
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/resources/Codelist/ML_gmxCodelists.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/resources/Codelist/gmxCodelists.xml
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/xlink/version.txt
# modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/xlink/xlinks.xsd
# modified: web/src/main/webapp/WEB-INF/schemaplugin-uri-catalog.xml
# modified:
web/src/main/webapp/conversion/iso19115-to-iso19139/iso-mapping.xml
# modified: web/src/main/webapp/geonetwork_map.css
# modified:
web/src/main/webapp/htmlCache/schematronscripts/schematron-frame.html
# modified: web/src/main/webapp/htmlCache/schematronscripts/verbid.xsl
# modified: web/src/main/webapp/loc/ita/xml/confirm.xml
# modified: web/src/main/webapp/loc/ita/xml/feedback-sent.xml
# modified: web/src/main/webapp/loc/ita/xml/iso-languages.xml
# modified: web/src/main/webapp/loc/ita/xml/metadata-create.xml
# modified: web/src/main/webapp/loc/ita/xml/metadata-delete.xml
# modified: web/src/main/webapp/loc/ita/xml/metadata-searchunused.xml
# modified: web/src/main/webapp/loc/ita/xml/metadata-validate.xml
# modified: web/src/main/webapp/loc/ita/xml/password-changed.xml
# modified: web/src/main/webapp/loc/ita/xml/validation-error.xml
# modified: web/src/main/webapp/loc/pol/xml/about.xml
# modified: web/src/main/webapp/loc/pol/xml/help.xml
# modified: web/src/main/webapp/loc/pol/xml/iso-languages.xml
# modified: web/src/main/webapp/loc/tur/xml/about.xml
# modified: web/src/main/webapp/loc/tur/xml/config.xml
# modified: web/src/main/webapp/loc/tur/xml/error.xml
# modified: web/src/main/webapp/loc/tur/xml/help.xml
# modified: web/src/main/webapp/loc/tur/xml/info-changed.xml
# modified: web/src/main/webapp/loc/tur/xml/login-error.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-batchDelete.xml
# modified:
web/src/main/webapp/loc/tur/xml/metadata-batchUpdateCategories.xml
# modified:
web/src/main/webapp/loc/tur/xml/metadata-batchXslProcessing.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-create.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-massiveDelete.xml
# modified:
web/src/main/webapp/loc/tur/xml/metadata-massiveUpdateCategories.xml
# modified:
web/src/main/webapp/loc/tur/xml/metadata-massiveXslProcessing.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-searchunused.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-show-error.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-thumbnail.xml
# modified: web/src/main/webapp/loc/tur/xml/metadata-validate.xml
# modified: web/src/main/webapp/loc/tur/xml/password-changed.xml
# modified: web/src/main/webapp/loc/tur/xml/privileges-error.xml
# modified: web/src/main/webapp/loc/tur/xml/registration-error.xml
# modified: web/src/main/webapp/loc/tur/xml/registration-sent.xml
# modified: web/src/main/webapp/loc/tur/xml/strings.xml
# modified: web/src/main/webapp/loc/tur/xml/validation-error.xml
# modified: web/src/main/webapp/maps/geoserver_localhost.wmc
# modified: web/src/main/webapp/modalbox.css
# modified: web/src/main/webapp/scripts/editor/metadata-editor.js
# modified: web/src/main/webapp/scripts/ext/adapter/ext/ext-base.js
# modified:
web/src/main/webapp/scripts/ext/adapter/jquery/ext-jquery-adapter.js
# modified:
web/src/main/webapp/scripts/ext/adapter/prototype/ext-prototype-adapter.js
# modified:
web/src/main/webapp/scripts/ext/adapter/yui/ext-yui-adapter.js
# modified: web/src/main/webapp/scripts/ext/air/air.jsb
# modified: web/src/main/webapp/scripts/ext/air/ext-air.js
# modified:
web/src/main/webapp/scripts/ext/air/resources/air-resources.jsb
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/air/AIRAliases.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/air/AIRIntrospector.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/extjs/adapter/ext/ext-base.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/extjs/ext-air-debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/extjs/ext-air.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/extjs/ext-all-debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/extjs/ext-all.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/ChromeViewport.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/Debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/SliderMenu.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/Xp.ui.CurrentInfo.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/Xp.ui.Main.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/Xp.ui.Playlist.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/ExtPlayer/js/Xp.ui.Templates.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/air/AIRAliases.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/air/AIRIntrospector.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/extjs/adapter/ext/ext-base.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/extjs/ext-air-debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/extjs/ext-air.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/extjs/ext-all-debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/helloworld/extjs/ext-all.js
# modified: web/src/main/webapp/scripts/ext/air/samples/tasks/.project
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/adobe/AIRAliases.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/adobe/AIRIntrospector.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/extjs/adapter/ext/ext-base.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/extjs/ext-air-debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/extjs/ext-air.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/extjs/ext-all-debug.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/extjs/ext-all.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/DateTimeField.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/Exporter.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/Importer.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/ListLoader.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/ListSelector.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/ListStore.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/ListTree.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/Reminder.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/SelectBox.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/SwitchButton.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/TaskGrid.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/TaskStore.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/TaskWindow.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/Templates.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/TextDate.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/TreeSelector.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/columns.js
# modified: web/src/main/webapp/scripts/ext/air/samples/tasks/js/data.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/js/ext-config.js
# modified: web/src/main/webapp/scripts/ext/air/samples/tasks/main.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/preferences.js
# modified:
web/src/main/webapp/scripts/ext/air/samples/tasks/reminder.js
# modified: web/src/main/webapp/scripts/ext/air/samples/tasks/task.js
# modified: web/src/main/webapp/scripts/ext/air/src/App.js
# modified: web/src/main/webapp/scripts/ext/air/src/Clipboard.js
# modified: web/src/main/webapp/scripts/ext/air/src/Debug.js
# modified: web/src/main/webapp/scripts/ext/air/src/FileProvider.js
# modified: web/src/main/webapp/scripts/ext/air/src/FileTreeLoader.js
# modified: web/src/main/webapp/scripts/ext/air/src/MusicPlayer.js
# modified: web/src/main/webapp/scripts/ext/air/src/NativeDD.js
# modified: web/src/main/webapp/scripts/ext/air/src/NativeObservable.js
# modified: web/src/main/webapp/scripts/ext/air/src/NativeWindow.js
# modified: web/src/main/webapp/scripts/ext/air/src/Notify.js
# modified: web/src/main/webapp/scripts/ext/air/src/Sound.js
# modified: web/src/main/webapp/scripts/ext/air/src/SystemMenu.js
# modified: web/src/main/webapp/scripts/ext/air/src/SystemTray.js
# modified: web/src/main/webapp/scripts/ext/air/src/VideoPanel.js
# modified: web/src/main/webapp/scripts/ext/air/src/air.jsb
# modified: web/src/main/webapp/scripts/ext/air/src/ext-air-adapter.js
# modified: web/src/main/webapp/scripts/ext/air/src/sql/AirConnection.js
# modified: web/src/main/webapp/scripts/ext/air/src/sql/Connection.js
# modified: web/src/main/webapp/scripts/ext/air/src/sql/Proxy.js
# modified: web/src/main/webapp/scripts/ext/air/src/sql/SQLiteStore.js
# modified: web/src/main/webapp/scripts/ext/air/src/sql/Table.js
# modified:
web/src/main/webapp/scripts/ext/build/adapter/ext-base-min.js
# modified:
web/src/main/webapp/scripts/ext/build/adapter/jquery-bridge-min.js
# modified:
web/src/main/webapp/scripts/ext/build/adapter/prototype-bridge-min.js
# modified:
web/src/main/webapp/scripts/ext/build/adapter/yui-bridge-min.js
# modified:
web/src/main/webapp/scripts/ext/build/core/CompositeElement-min.js
# modified: web/src/main/webapp/scripts/ext/build/core/DomHelper-min.js
# modified: web/src/main/webapp/scripts/ext/build/core/DomQuery-min.js
# modified: web/src/main/webapp/scripts/ext/build/core/Element-min.js
# modified:
web/src/main/webapp/scripts/ext/build/core/EventManager-min.js
# modified: web/src/main/webapp/scripts/ext/build/core/Ext-min.js
# modified: web/src/main/webapp/scripts/ext/build/core/Fx-min.js
# modified: web/src/main/webapp/scripts/ext/build/core/Template-min.js
# modified:
web/src/main/webapp/scripts/ext/build/core/UpdateManager-min.js
# modified:
web/src/main/webapp/scripts/ext/build/data/ArrayReader-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/Connection-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/DataField-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/DataProxy-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/DataReader-min.js
# modified:
web/src/main/webapp/scripts/ext/build/data/GroupingStore-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/HttpProxy-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/JsonReader-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/JsonStore-min.js
# modified:
web/src/main/webapp/scripts/ext/build/data/MemoryProxy-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/Record-min.js
# modified:
web/src/main/webapp/scripts/ext/build/data/ScriptTagProxy-min.js
# modified:
web/src/main/webapp/scripts/ext/build/data/SimpleStore-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/SortTypes-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/Store-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/StoreMgr-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/Tree-min.js
# modified: web/src/main/webapp/scripts/ext/build/data/XmlReader-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/DDCore-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/DragSource-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/DragTracker-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/DragZone-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/DropTarget-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/DropZone-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/Registry-min.js
# modified:
web/src/main/webapp/scripts/ext/build/dd/ScrollManager-min.js
# modified: web/src/main/webapp/scripts/ext/build/dd/StatusProxy-min.js
# modified: web/src/main/webapp/scripts/ext/build/debug-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-af-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-bg-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-ca-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-cs-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-da-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-de-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-el_GR-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-en-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-en_GB-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-es-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-fa-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-fi-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-fr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-fr_CA-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-gr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-he-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-hr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-hu-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-id-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-it-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-ja-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-ko-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-lt-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-lv-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-mk-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-nl-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-no_NB-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-no_NN-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-pt-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-pt_BR-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-ro-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-ru-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-sk-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-sl-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-sr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-sr_RS-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-sv_SE-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-th-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-tr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-ukr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-vn-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-zh_CN-min.js
# modified:
web/src/main/webapp/scripts/ext/build/locale/ext-lang-zh_TW-min.js
# modified:
web/src/main/webapp/scripts/ext/build/state/CookieProvider-min.js
# modified: web/src/main/webapp/scripts/ext/build/state/Provider-min.js
# modified:
web/src/main/webapp/scripts/ext/build/state/StateManager-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/CSS-min.js
# modified:
web/src/main/webapp/scripts/ext/build/util/ClickRepeater-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/Date-min.js
# modified:
web/src/main/webapp/scripts/ext/build/util/DelayedTask-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/Format-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/History-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/JSON-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/KeyMap-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/KeyNav-min.js
# modified:
web/src/main/webapp/scripts/ext/build/util/MixedCollection-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/Observable-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/TaskMgr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/util/TextMetrics-min.js
# modified: web/src/main/webapp/scripts/ext/build/util/XTemplate-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Action-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/BoxComponent-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Button-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/ColorPalette-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/Component-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/ComponentMgr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/Container-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/CycleButton-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/DataView-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/DatePicker-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Editor-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Layer-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/LoadMask-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/MessageBox-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/PagingToolbar-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Panel-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/PanelDD-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/ProgressBar-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/Resizable-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Shadow-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Slider-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/SplitBar-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/SplitButton-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/StatusBar-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/TabPanel-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Toolbar-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/Viewport-min.js
# modified: web/src/main/webapp/scripts/ext/build/widgets/Window-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/WindowManager-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Action-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/BasicForm-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Checkbox-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/CheckboxGroup-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Combo-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/DateField-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Field-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/FieldSet-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Form-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Hidden-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/HtmlEditor-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Label-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/NumberField-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/Radio-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/RadioGroup-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/TextArea-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/TextField-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/TimeField-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/TriggerField-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/form/VTypes-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/AbstractSelectionModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/CellSelectionModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/CheckboxSelectionModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/ColumnDD-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/ColumnModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/ColumnSplitDD-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/EditorGrid-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/GridDD-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/GridEditor-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/GridPanel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/GridView-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/GroupingView-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/PropertyGrid-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/RowNumberer-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/grid/RowSelectionModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/AbsoluteLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/AccordionLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/AnchorLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/BorderLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/CardLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/ColumnLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/ContainerLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/FitLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/FormLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/layout/TableLayout-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/Adapter-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/BaseItem-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/CheckItem-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/ColorItem-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/ColorMenu-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/DateItem-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/DateMenu-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/Item-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/Menu-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/MenuMgr-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/Separator-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/menu/TextItem-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tips/QuickTip-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tips/QuickTips-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tips/Tip-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tips/ToolTip-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/AsyncTreeNode-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeDragZone-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeDropZone-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeEditor-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeEventModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeFilter-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeLoader-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeNode-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeNodeUI-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreePanel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeSelectionModel-min.js
# modified:
web/src/main/webapp/scripts/ext/build/widgets/tree/TreeSorter-min.js
# modified: web/src/main/webapp/scripts/ext/ext-all-debug.js
# modified: web/src/main/webapp/scripts/ext/ext-all.js
# modified: web/src/main/webapp/scripts/ext/ext-core-debug.js
# modified: web/src/main/webapp/scripts/ext/ext-core.js
# modified:
web/src/main/webapp/scripts/ext/package/button/button-debug.js
# modified: web/src/main/webapp/scripts/ext/package/button/button.js
# modified: web/src/main/webapp/scripts/ext/package/color-palette.js
# modified: web/src/main/webapp/scripts/ext/package/data/data.js
# modified: web/src/main/webapp/scripts/ext/package/date.js
# modified:
web/src/main/webapp/scripts/ext/package/datepicker/datepicker.js
# modified:
web/src/main/webapp/scripts/ext/package/dialog/dialogs-debug.js
# modified: web/src/main/webapp/scripts/ext/package/dialog/dialogs.js
# modified: web/src/main/webapp/scripts/ext/package/dragdrop/dragdrop.js
# modified: web/src/main/webapp/scripts/ext/package/form/form-debug.js
# modified: web/src/main/webapp/scripts/ext/package/form/form.js
# modified:
web/src/main/webapp/scripts/ext/package/grid/edit-grid-debug.js
# modified: web/src/main/webapp/scripts/ext/package/grid/edit-grid.js
# modified: web/src/main/webapp/scripts/ext/package/grid/grid.js
# modified: web/src/main/webapp/scripts/ext/package/menu/menus.js
# modified: web/src/main/webapp/scripts/ext/package/qtips/qtips.js
# modified: web/src/main/webapp/scripts/ext/package/resizable.js
# modified: web/src/main/webapp/scripts/ext/package/splitbar.js
# modified: web/src/main/webapp/scripts/ext/package/tabs/tabs.js
# modified: web/src/main/webapp/scripts/ext/package/toolbar/toolbar.js
# modified: web/src/main/webapp/scripts/ext/package/tree/tree.js
# modified: web/src/main/webapp/scripts/ext/package/util.js
# modified: web/src/main/webapp/scripts/ext/package/widget-core.js
# modified: web/src/main/webapp/scripts/ext/resources/resources.jsb
# modified: web/src/main/webapp/scripts/ext/source/adapter/ext-base.js
# modified:
web/src/main/webapp/scripts/ext/source/adapter/jquery-bridge.js
# modified:
web/src/main/webapp/scripts/ext/source/adapter/prototype-bridge.js
# modified: web/src/main/webapp/scripts/ext/source/adapter/yui-bridge.js
# modified:
web/src/main/webapp/scripts/ext/source/core/CompositeElement.js
# modified: web/src/main/webapp/scripts/ext/source/core/DomHelper.js
# modified: web/src/main/webapp/scripts/ext/source/core/DomQuery.js
# modified: web/src/main/webapp/scripts/ext/source/core/Element.js
# modified: web/src/main/webapp/scripts/ext/source/core/EventManager.js
# modified: web/src/main/webapp/scripts/ext/source/core/Ext.js
# modified: web/src/main/webapp/scripts/ext/source/core/Fx.js
# modified: web/src/main/webapp/scripts/ext/source/core/Template.js
# modified: web/src/main/webapp/scripts/ext/source/core/UpdateManager.js
# modified: web/src/main/webapp/scripts/ext/source/data/ArrayReader.js
# modified: web/src/main/webapp/scripts/ext/source/data/Connection.js
# modified: web/src/main/webapp/scripts/ext/source/data/DataField.js
# modified: web/src/main/webapp/scripts/ext/source/data/DataProxy.js
# modified: web/src/main/webapp/scripts/ext/source/data/DataReader.js
# modified: web/src/main/webapp/scripts/ext/source/data/GroupingStore.js
# modified: web/src/main/webapp/scripts/ext/source/data/HttpProxy.js
# modified: web/src/main/webapp/scripts/ext/source/data/JsonReader.js
# modified: web/src/main/webapp/scripts/ext/source/data/JsonStore.js
# modified: web/src/main/webapp/scripts/ext/source/data/MemoryProxy.js
# modified: web/src/main/webapp/scripts/ext/source/data/Record.js
# modified:
web/src/main/webapp/scripts/ext/source/data/ScriptTagProxy.js
# modified: web/src/main/webapp/scripts/ext/source/data/SimpleStore.js
# modified: web/src/main/webapp/scripts/ext/source/data/SortTypes.js
# modified: web/src/main/webapp/scripts/ext/source/data/Store.js
# modified: web/src/main/webapp/scripts/ext/source/data/StoreMgr.js
# modified: web/src/main/webapp/scripts/ext/source/data/Tree.js
# modified: web/src/main/webapp/scripts/ext/source/data/XmlReader.js
# modified: web/src/main/webapp/scripts/ext/source/dd/DDCore.js
# modified: web/src/main/webapp/scripts/ext/source/dd/DragSource.js
# modified: web/src/main/webapp/scripts/ext/source/dd/DragTracker.js
# modified: web/src/main/webapp/scripts/ext/source/dd/DragZone.js
# modified: web/src/main/webapp/scripts/ext/source/dd/DropTarget.js
# modified: web/src/main/webapp/scripts/ext/source/dd/DropZone.js
# modified: web/src/main/webapp/scripts/ext/source/dd/Registry.js
# modified: web/src/main/webapp/scripts/ext/source/dd/ScrollManager.js
# modified: web/src/main/webapp/scripts/ext/source/dd/StatusProxy.js
# modified: web/src/main/webapp/scripts/ext/source/debug.js
# modified: web/src/main/webapp/scripts/ext/source/ext.jsb
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-af.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-bg.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-ca.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-cs.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-da.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-de.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-el_GR.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-en.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-en_GB.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-es.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-fa.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-fi.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-fr.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-fr_CA.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-gr.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-he.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-hr.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-hu.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-id.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-it.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-ja.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-ko.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-lt.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-lv.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-mk.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-nl.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-no_NB.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-no_NN.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-pt.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-pt_BR.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-ro.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-ru.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-sk.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-sl.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-sr.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-sr_RS.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-sv_SE.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-th.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-tr.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-ukr.js
# modified: web/src/main/webapp/scripts/ext/source/locale/ext-lang-vn.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-zh_CN.js
# modified:
web/src/main/webapp/scripts/ext/source/locale/ext-lang-zh_TW.js
# modified:
web/src/main/webapp/scripts/ext/source/state/CookieProvider.js
# modified: web/src/main/webapp/scripts/ext/source/state/Provider.js
# modified: web/src/main/webapp/scripts/ext/source/state/StateManager.js
# modified: web/src/main/webapp/scripts/ext/source/util/CSS.js
# modified: web/src/main/webapp/scripts/ext/source/util/ClickRepeater.js
# modified: web/src/main/webapp/scripts/ext/source/util/Date.js
# modified: web/src/main/webapp/scripts/ext/source/util/DelayedTask.js
# modified: web/src/main/webapp/scripts/ext/source/util/Format.js
# modified: web/src/main/webapp/scripts/ext/source/util/History.js
# modified: web/src/main/webapp/scripts/ext/source/util/JSON.js
# modified: web/src/main/webapp/scripts/ext/source/util/KeyMap.js
# modified: web/src/main/webapp/scripts/ext/source/util/KeyNav.js
# modified:
web/src/main/webapp/scripts/ext/source/util/MixedCollection.js
# modified: web/src/main/webapp/scripts/ext/source/util/Observable.js
# modified: web/src/main/webapp/scripts/ext/source/util/TaskMgr.js
# modified: web/src/main/webapp/scripts/ext/source/util/TextMetrics.js
# modified: web/src/main/webapp/scripts/ext/source/util/XTemplate.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Action.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/BoxComponent.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Button.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/ColorPalette.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Component.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/ComponentMgr.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Container.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/CycleButton.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/DataView.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/DatePicker.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Editor.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Layer.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/LoadMask.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/MessageBox.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/PagingToolbar.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Panel.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/PanelDD.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/ProgressBar.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Resizable.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Shadow.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Slider.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/SplitBar.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/SplitButton.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/StatusBar.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/TabPanel.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Toolbar.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Viewport.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/Window.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/WindowManager.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/Action.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/BasicForm.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/Checkbox.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/CheckboxGroup.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/form/Combo.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/DateField.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/form/Field.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/FieldSet.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/form/Form.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/Hidden.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/HtmlEditor.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/form/Label.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/NumberField.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/form/Radio.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/RadioGroup.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/TextArea.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/TextField.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/TimeField.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/TriggerField.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/form/VTypes.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/AbstractSelectionModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/CellSelectionModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/CheckboxSelectionModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/ColumnDD.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/ColumnModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/ColumnSplitDD.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/EditorGrid.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/GridDD.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/GridEditor.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/GridPanel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/GridView.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/GroupingView.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/PropertyGrid.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/RowNumberer.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/grid/RowSelectionModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/AbsoluteLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/AccordionLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/AnchorLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/BorderLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/CardLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/ColumnLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/ContainerLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/FitLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/FormLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/layout/TableLayout.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/Adapter.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/BaseItem.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/CheckItem.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/ColorItem.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/ColorMenu.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/DateItem.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/DateMenu.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/menu/Item.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/menu/Menu.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/MenuMgr.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/Separator.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/menu/TextItem.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tips/QuickTip.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tips/QuickTips.js
# modified: web/src/main/webapp/scripts/ext/source/widgets/tips/Tip.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tips/ToolTip.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/AsyncTreeNode.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeDragZone.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeDropZone.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeEditor.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeEventModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeFilter.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeLoader.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeNode.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeNodeUI.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreePanel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeSelectionModel.js
# modified:
web/src/main/webapp/scripts/ext/source/widgets/tree/TreeSorter.js
# modified: web/src/main/webapp/scripts/form_check.js
# modified: web/src/main/webapp/scripts/geo/proj4js-compressed.js
# modified:
web/src/main/webapp/scripts/geoext/lib/GeoExt/data/FeatureRecord.js
# modified:
web/src/main/webapp/scripts/geoext/lib/GeoExt/data/LayerRecord.js
# modified:
web/src/main/webapp/scripts/geoext/lib/GeoExt/data/LayerStore.js
# modified:
web/src/main/webapp/scripts/geoext/lib/GeoExt/data/ScaleStore.js
# modified:
web/src/main/webapp/scripts/geoext/lib/GeoExt/widgets/Action.js
# modified:
web/src/main/webapp/scripts/geoext/lib/GeoExt/widgets/LegendImage.js
# modified: web/src/main/webapp/scripts/geonetwork.js
# modified: web/src/main/webapp/scripts/harvesting/arcsde/arcsde.js
# modified: web/src/main/webapp/scripts/harvesting/arcsde/model.js
# modified: web/src/main/webapp/scripts/harvesting/arcsde/view.js
# modified:
web/src/main/webapp/scripts/harvesting/filesystem/filesystem.js
# modified: web/src/main/webapp/scripts/harvesting/filesystem/model.js
# modified: web/src/main/webapp/scripts/harvesting/filesystem/view.js
# modified: web/src/main/webapp/scripts/lib/.ignore
# modified: web/src/main/webapp/scripts/map/lang/no.js
# modified: web/src/main/webapp/scripts/ol_map.js
# modified: web/src/main/webapp/scripts/ol_minimap.js
# modified:
web/src/main/webapp/scripts/openlayers/addins/LoadingPanel.js
# modified: web/src/main/webapp/scripts/openlayers/addins/ScaleBar.js
# modified:
web/src/main/webapp/scripts/openlayers/lib/OpenLayers/Format/SOSGetObservation.js
# modified:
web/src/main/webapp/scripts/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1_3.js
# modified:
web/src/main/webapp/scripts/openlayers/lib/OpenLayers/Format/WMSCapabilities/v1_3_0.js
no changes added to commit (use "git add" and/or "git commit -a")
Ok Thanks for the feedback. I think I am going to create a new Linux VM instance and do the checkout and see if I can reproduce the issue.
Could you try a couple things for me:
  1. execute: (the following are Linux instructions not for windows)
  2. git config --global core.autocrlf input
  3. git rm --cached -r .
  4. git reset --hard1. do: git status and see if the list of modified files change?
Jesse
Sent: ‎Wednesday‎, ‎March‎ ‎27‎, ‎2013 ‎1‎:‎30‎ ‎PM
To: Jesse Eichar
Cc: Devel geonetwork-devel@lists.sourceforge.net
<jesse.eichar@…189…> wrote:
Hi, I recently switched from a Mac to a windows machine and found that as
soon as I checked out core-geonetwork there were several complaints about
line endings.
I looked through the help on Github and came up with a page explaining the
steps to take for line-normalization. They looked simple and in fact when I
tried them out it seemed only a few files were affected so I committed the
changes.
Since then Maria and Francois have reported problems on their Linux machines
with line endings. So I installed Linux Mint and did a clone. I have
played with that install and clone and have had no problems. But Francois
has continued to have issues.
I would like people on Macs and Linux who have this problem to first try
making a clean clone of the repository and if they still have line-ending
problems to let me know which files they are and how many.
Likely we will have to commit some of these files but we need to try to keep
them to a minimum for merging.
Tip: If you have merge problems try:
git merge -s ignore-all-space
Jesse
Own the Future-Intel® Level Up Game Demo Contest 2013
Rise to greatness in Intel’s independent game demo contest.
Compete for recognition, cash, and the chance to get your game
on Steam. $5K grand prize plus 10 genre and skill prizes.
Submit your demo by 6/6/13. http://p.sf.net/sfu/intel_levelupd2d
GeoNetwork-devel mailing list
I tried on a new Ubuntu 12.04 and this is the result (very long). It
doesn’t matter if I try to reset hard or checkout the files, the
problem is there:
root@…945… /tmp # git clone
git://github.com/geonetwork/core-geonetwork.git test
Cloning into ‘test’…
remote: Counting objects: 75264, done.
remote: Compressing objects: 100% (25620/25620), done.
remote: Total 75264 (delta 45595), reused 73605 (delta 44287)
Receiving objects: 100% (75264/75264), 112.02 MiB | 23.91 MiB/s, done.
Resolving deltas: 100% (45595/45595), done.
root@…945… /tmp # cd test
root@…945… /tmp/test # git status
On branch master
Changes not staged for commit:
(use “git add …” to update what will be committed)
(use “git checkout – …” to discard changes in working
directory)
modified:
cachingxslt/src/main/java/de/fzi/dbs/xml/transform/CachingTransformerFactory.java
modified: cswtest/TEST-org.fao.geonet.csw.TestCswIsoApp.xml
modified:
jeeves/src/main/java/jeeves/utils/TransformerFactoryFactory.java
modified:
oaipmh/src/main/java/org/fao/oaipmh/requests/TokenListRequest.java
modified:
sde/src/main/java/com/esri/sde/sdk/GeoToolsDummyAPI.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SDEPoint.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeColumnDefinition.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeConnection.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeCoordinateReference.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDBMSInfo.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDBTune.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDefs.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDelete.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeDoesNotExistException.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeError.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeException.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeExtent.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeFilter.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeInsert.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeInstance.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeLayer.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeObjectId.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeQuery.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeQueryInfo.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRaster.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterAttr.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterBand.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterColumn.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterConstraint.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterConsumer.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterProducer.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterRenderedImage.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterScanLineGenerator.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterScanLineProducer.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRasterTile.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRegistration.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeRelease.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeRow.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeServerObj.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeShape.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeShapeFilter.java
modified:
sde/src/main/java/com/esri/sde/sdk/client/SeSqlConstruct.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeState.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeStreamOp.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeTable.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeUpdate.java
modified: sde/src/main/java/com/esri/sde/sdk/client/SeVersion.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/EmptyType.java
modified:
sde/src/main/java/com/esri/sde/sdk/pe/PeCoordinateSystem.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/PeFactory.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/PePCSDefs.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/PeParameters.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/PeProjectedCS.java
modified:
sde/src/main/java/com/esri/sde/sdk/pe/PeProjectionException.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/PeUnit.java
modified: sde/src/main/java/com/esri/sde/sdk/pe/PeUnitsDefs.java
modified: web-client/src/main/resources/apps/css/gnmapdefault.css
modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/FeatureRecord.js
modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/LayerRecord.js
modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/LayerStore.js
modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/data/ScaleStore.js
modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/widgets/Action.js
modified:
web-client/src/main/resources/apps/js/GeoExt/lib/GeoExt/widgets/LegendImage.js
modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/form/GeometryMapField.js
modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/lang/de.js
modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/CategoryView.js
modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/FacetsPanel.js
modified:
web-client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/editor/EditorTools.js
modified:
web-client/src/main/resources/apps/js/OpenLayers/lib/OpenLayers/Format/WMSCapabilities/v1_3.js
modified:
web-client/src/main/resources/apps/js/OpenLayers/lib/OpenLayers/Format/WMSCapabilities/v1_3_0.js
modified:
web-client/src/main/resources/apps/js/ext/ext-all-debug-w-comments.js
modified: web-client/src/main/resources/apps/js/ext/ext-all-debug.js
modified:
web-client/src/main/resources/apps/js/ext/pkgs/cmp-foundation-debug.js
modified:
web/src/main/java/org/fao/geonet/arcgis/ArcSDEConnection.java
modified:
web/src/main/java/org/fao/geonet/arcgis/ArcSDEMetadataAdapter.java
modified:
web/src/main/java/org/fao/geonet/csw/common/ConstraintLanguage.java
modified:
web/src/main/java/org/fao/geonet/csw/common/CswOperation.java
modified:
web/src/main/java/org/fao/geonet/csw/common/ElementSetName.java
modified:
web/src/main/java/org/fao/geonet/csw/common/OutputFormatPreference.java
modified:
web/src/main/java/org/fao/geonet/csw/common/OutputSchema.java
modified:
web/src/main/java/org/fao/geonet/csw/common/OutputSchemaPreference.java
modified: web/src/main/java/org/fao/geonet/csw/common/Section.java
modified: web/src/main/java/org/fao/geonet/csw/common/TypeName.java
modified: web/src/main/java/org/fao/geonet/csw/common/util/Xml.java
modified:
web/src/main/java/org/fao/geonet/exceptions/UnAuthorizedException.java
modified:
web/src/main/java/org/fao/geonet/guiservices/metadata/Sitemap.java
modified: web/src/main/java/org/fao/geonet/kernel/KeywordBean.java
modified:
web/src/main/java/org/fao/geonet/kernel/MetadataIndexerProcessor.java
modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEHarvester.java
modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/arcsde/ArcSDEParams.java
modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/localfilesystem/LocalFilesystemHarvester.java
modified:
web/src/main/java/org/fao/geonet/kernel/harvest/harvester/localfilesystem/LocalFilesystemParams.java
modified:
web/src/main/java/org/fao/geonet/kernel/oaipmh/ResumptionTokenCache.java
modified:
web/src/main/java/org/fao/geonet/kernel/oaipmh/services/AbstractTokenLister.java
modified:
web/src/main/java/org/fao/geonet/kernel/search/GeoNetworkAnalyzer.java
modified:
web/src/main/java/org/fao/geonet/kernel/search/LuceneIndexField.java
modified:
web/src/main/java/org/fao/geonet/kernel/search/LuceneQueryBuilder.java
modified:
web/src/main/java/org/fao/geonet/kernel/search/LuceneUtils.java
modified:
web/src/main/java/org/fao/geonet/kernel/search/StopwordFileParser.java
modified:
web/src/main/java/org/fao/geonet/services/metadata/BatchOpsMetadataReindexer.java
modified:
web/src/main/java/org/fao/geonet/services/notifications/domain/NotificationTarget.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/Activate.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/AddElement.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/Clear.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/DeleteElement.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/Download.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/EditElement.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetKeywordById.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetKeywords.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetList.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetNarrowerBroader.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/GetSelectedKeywords.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/List.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/SelectKeywords.java
modified:
web/src/main/java/org/fao/geonet/services/thesaurus/UpdateElement.java
modified:
web/src/main/java/org/fao/geonet/services/util/ServiceMetadataReindexer.java
modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUArgumentParseException.java
modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUDiag.java
modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUParamTestDBO.java
modified:
web/src/main/java/org/fao/geonet/services/util/z3950/SRUParamTester.java
modified: web/src/main/java/org/fao/geonet/util/HeapSorter.java
modified:
web/src/main/java/org/fao/geonet/util/XMLExtensionFilenameFilter.java
modified: web/src/main/java/org/fao/geonet/util/ZipUtil.java
modified: web/src/main/webResources/WEB-INF/server.prop
modified: web/src/main/webapp/WEB-INF/classes/JZKitConfig.xml.tem
modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_abstract_expand.xsl
modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_dsdl_include.xsl
modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_schematron_message_xslt2.xsl
modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_schematron_skeleton_for_saxon.xsl
modified:
web/src/main/webapp/WEB-INF/classes/schematron/iso_svrl_for_xslt2.xsl
modified: web/src/main/webapp/WEB-INF/classes/schematron/readme.txt
modified:
web/src/main/webapp/WEB-INF/classes/schematron/sch-messages-ger.xhtml
modified:
web/src/main/webapp/WEB-INF/classes/setup/sql/data/loc-pol-default.sql
modified:
web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v280/loc-pol-default.sql
modified:
web/src/main/webapp/WEB-INF/classes/setup/sql/migrate/v280/loc-rus-default.sql
modified:
web/src/main/webapp/WEB-INF/data/config/codelist/external/thesauri/place/regions.rdf
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/dublin-core/loc/tur/labels.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/fgdc-std/templates/metadata.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/loc/nor/codelists.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/loc/nor/labels.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/present/csw/ogc-brief.xsl
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/present/csw/ogc-full.xsl
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/present/csw/ogc-summary.xsl
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19115/update-fixed-info.xsl
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/convert/ThreddsDIFToISO/DIFToISO.xsl
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/convert/thesaurus-transformation.xsl
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/loc/fre/codelists.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gco/gcoBase.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/basicTypes.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/coordinateOperations.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/coordinateReferenceSystems.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/coordinateSystems.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/dictionary.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/direction.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/geometryAggregates.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/geometryBasic2d.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/geometryComplexes.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/gml.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/gmlBase.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/grids.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/measures.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/readme.txt
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/referenceSystems.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/temporalTopology.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/topology.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/units.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/gml/valueObjects.xsd
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/resources/Codelist/ML_gmxCodelists.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/resources/Codelist/gmxCodelists.xml
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/xlink/version.txt
modified:
web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/schema/xlink/xlinks.xsd
modified: web/src/main/webapp/WEB-INF/schemaplugin-uri-catalog.xml
modified:
web/src/main/webapp/conversion/iso19115-to-iso19139/iso-mapping.xml
modified: web/src/main/webapp/geonetwork_map.css
modified:
web/src/main/webapp/htmlCache/schematronscripts/schematron-frame.html
modified: web/src/main/webapp/htmlCache/schematronscripts/verbid.xsl
modified: web/src/main/webapp/loc/ita/xml/confirm.xml
modified: web/src/main/webapp/loc/ita/xml/feedback-sent.xml
modified: web/src/main/webapp/loc/ita/xml/iso-languages.xml
modified: web/src/main/webapp/loc/ita/xml/metadata-create.xml
modified: web/src/main/webapp/loc/ita/xml/metadata-delete.xml
modified: web/src/main/webapp/loc/ita/xml/metadata-searchunused.xml
modified: web/src/main/webapp/loc/ita/xml/metadata-validate.xml
modified: web/src/main/webapp/loc/ita/xml/password-changed.xml
modified: web/src/main/webapp/loc/ita/xml/validation-error.xml
modified: web/src/main/webapp/loc/pol/xml/about.xml
modified: web/src/main/webapp/loc/pol/xml/help.xml
modified: web/src/main/webapp/loc/pol/xml/iso-languages.xml
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
modified:
no changes added to commit (use “git add” and/or “git commit -a”)
I have made a brand new Linux mint vm image with a swiss locale and I have been able to reproduce the line end issue reported by FX and Maria. I am going to do some tests locally to see how hard it is to remove this issue.
I have 2 ideas:
  1. Commit the files with the new line endings. This will require all branches to do a merge with the ignore whitespace option. I will test this to see how realistic it is
  2. Remove the .gitattributes file and hope that I don’t cause more problems as I continue to work on windows.
Jesse
Jesse,
Have you tried "git config --global core.autocrlf false" in your windows
setup....
http://stackoverflow.com/questions/4181870/git-on-windows-what-do-the-crlf-settings-mean
View this message in context: http://osgeo-org.1560.n6.nabble.com/repository-and-line-normalization-tp5042893p5043513.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Sent: ‎Thursday‎, ‎March‎ ‎28‎, ‎2013 ‎12‎:‎28‎ ‎PM
To: geonetwork-devel@lists.sourceforge.net
Jesse,
Have you tried “git config --global core.autocrlf false” in your windows
setup…
I have read that. We can do that but it is usually not recommended because line endings shouldn’t really cause a conflict. I remember constantly having that problem when we used SVN and the configuration files all had the CRLF line ending. It was actually the reason I originally made the ConfigurationOverrides.
I did a test today where I committed all the line ending changes and merged it to geocat using the command:
git merge -Xignore-all-space upstream/master
It worked perfectly so the merge of those line endings don’t seem to be a problem if the -X flag is used. There are other options as well like: -Xignore-space-at-eol and -Xignore-space-change
Jesse
Hi all, I’ve done the commit “7fb26a: Normalize line endings”
https://github.com/geonetwork/core-geonetwork/commit/7fb26a51aebc67296535fbd48a9252f74d4ef058
and tested 2 merges with success. Let us know if you’ve any issues now ?
Cheers.
Francois
2013/3/28 <jesse.eichar@…189…>
Sent: Thursday, March 28, 2013 12:28 PM
Jesse,
setup…
Jesse
