[GeoNetwork-devel] Request to become a committer on the geosource and geocat sandbox in SVN
Hi List,
For some background, I am working on the GeoSource project and also on the geocat.ch project for swisstopo. The main goals of these projects are documented here: http://n2.nabble.com/french-community…-tc1393262.html and http://www.nabble.com/Announcement-SwissTopo-developments-for-GeoNetwork-td20683715.html
I have read, understood, and agree to the committer responsibilities and guidelines documented at http://trac.osgeo.org/geonetwork/wiki/committer.
May I be granted access as a committer to the geosource and geocat sandbox area?
My username is mcoudert
Mathieu
Hi Mathieu,
I added you to the committers on SVN in the understanding that you will only commit to the sandboxes you indicated :slight_smile:
Please also add yourself to the committer mailing list if you didn’t do that yet, and add yourself to the list at:
http://trac.osgeo.org/geonetwork/wiki/committer_list
Looking forward to your valuable contributions!
Ciao,
Jeroen
On Dec 16, 2008, at 3:30 PM, Mathieu Coudert wrote:
Hi List,
Mathieu
SF.Net email is Sponsored by MIX09, March 18-20, 2009 in Las Vegas, Nevada.
The future of the web can’t happen without you. Join us at MIX09 to help
pave the way to the Next Web now. Learn more and register at
http://ad.doubleclick.net/clk;208669438;13503038;i?http://2009.visitmix.com/_______________________________________________
GeoNetwork-devel mailing list
Hi list,
For three years, I've been in charge of the project Geosource in France
based on GeoNetwork. Even if I'm not very active in the development, I
try to provide a consistence sandbox with GN trunk
May I be granted access as a committer to the geosource sandbox area?
My username is Pla
Pierre LAGARDE
BRGM - STI/DIR
0238643005
0610792973
Pensez a l'environnement avant d'imprimer ce message
Think Environment before printing
Le contenu de ce mel et de ses pieces jointes est destine a l'usage exclusif du (des) destinataire(s) designe
(s) comme tel(s).
En cas de reception par erreur, le signaler e son expediteur et ne pas en divulguer le contenu.
L'absence de virus a ete verifiee e l'emission, il convient neanmoins de s'assurer de l'absence de
contamination a sa reception.
The contents of this email and any attachments are confidential. They are intended for the named recipient
(s) only.
If you have received this email in error please notify the system manager or the sender immediately and do
not disclose the contents to anyone or make copies.
eSafe scanned this email for viruses, vandals and malicious content.
