I am working on a feature proposal requested by a client but there are a couple of options to satisfy the requirement.
Please read:
https://github.com/geonetwork/core-geonetwork/wiki/ValidationReport
and give me you thoughts on the proposal and which way you think it should be implemented.
I will collect the opinions, present it to the client and try to satisfy the majority the best I can.
Jesse
Hi Jesse
Looks a nice feature. Some comments:
- About displaying the validation status in search results, I like option 2, maybe the validation results should be only displayed only to logged users, so public users will see results as now, as not sure if this validation is relevant to these users.
Also can be useful anyway to allow in the system configuration to enable/disable the complete feature.
This proposed change would allow a user to select several metadata and then do a “special” search which displays the selected metadata in the search view with the validation status of each schematron file in each search result.
For the search filter, I just would use a similar approach as in first comment: for logged users display a panel in the search with the validation filters to apply. Depending on the filter, the results will display the metadata that fits that criteria. This will remove the need to select first any records and for me looks more clear.
Jose García
On Tue, Jan 28, 2014 at 9:31 PM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Please read:
Jesse
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Thanks Jose,
I have added you comments to the proposal.
On Wed, Jan 29, 2014 at 8:52 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jesse
Jose García
Please read:
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jesse,
I like the idea.
It would also be nice to add the field in the “sort by” fields.
I agree with Jose, It would be better if one could enable/disable this, through the system conf.
Jean
2014-01-29 Jesse Eichar <jesse.eichar@anonymised.com>
Thanks Jose,
On Wed, Jan 29, 2014 at 8:52 AM, Jose Garcia <jose.garcia@anonymised.com…> wrote:
Hi Jesse
Jose García
On Tue, Jan 28, 2014 at 9:31 PM, Jesse Eichar <jesse.eichar@anonymised.com9…> wrote:
Please read:
Jesse
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
