Hi!
I've been trying to run geonetwork inside eclipse, but it's not working.
I tried to follow this guide
http://osgeo-org.1803224.n2.nabble.com/Windows-GeoNetwork-Eclipse-Setup-Guide-First-Version-td4470162.html
but it's relatively old, since now the geonetwork directories are different.
What do i need to do, so i can run an debug geonetwork inside eclipse?
I've already checked out the source code from SVN, added the tomcat server
in eclipse, and the maven plugin is already installed on eclipse.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Run-Geonetwork-inside-eclipse-tp5376709p5376709.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
