I have a question in respect to run multiple installations of GeoNetwork on the same server. Usually you can run different java application in one servlet container (e.g. jetty) how it has been used for geonetwork, geoserver and intermap.
In the GNos administrators FAQ you can read ‘To run multiple instances you have to change the ports that GeoNetwork uses in order to avoid conflics’. That means I have to completely install a second GeoNetwork including jetty servlet engine.
So it is not possible to dublicate the GeoNetwork installation folder and link the second GeoNetwork in jettys webapps in the way
/geonetwork ../web/geonetwork /intermap ../web/intermap /geoserver ../web/geoserver /**secondGeonetwork**/ ../web/secondGeonetworkThe problem is that some of my clients can’t connect to the application trough ports other than :80 or :8080. Is there a possibility to run different GN installations on the same port?
Best regards,
Christian
