[GeoNetwork-devel] RV: How to modify metadata view
I am working on a custom installation of Geonetwork 2.10.4. At the moment I have downloaded the war, put it under Tomcat, connect to PostGis and do several layout modifications. So far so good.
The problem now is that I have been requested to customize both the simple and default view of the catalog metadata page. I need to remove some sections and show some other present in the metadata XML file. I have been searching deeply where this metadata views are generated, and I could not find what XSL renders the HTML that the server sends back to the client. I have found some good candidates, but no changes in them had any result in the page that shows up in the browser. Some of the XSL files that I have changes are metadata.xsl or metadata-edit.xsl.
So the thing is, what am I missing? Am I toching the wrong files or are there any other steps to take?
César
Tracasa
Hi César,
It depends.
Which UI are you using ?
Jean
*Jean Pommier -- pi-Geosolutions*
Ingénieur, consultant indépendant
Tél. : (+33) 6 09 23 21 36
E-mail : jp@anonymised.com
Web : www.pi-geosolutions.fr
Le 23/02/2015 10:39, César Díaz García a écrit :
César
Tracasa
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=190641631&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
(attachments)
I’m using the HTML5 UI.
César
(attachments)
De: Jean Pommier [mailto:jean.pommier@anonymised.com]
Enviado el: lunes, 23 de febrero de 2015 10:57
Para: César Díaz García; geonetwork-devel@anonymised.comt
Asunto: Re: [GeoNetwork-devel] RV: How to modify metadata view
Hi César,
It depends.
Jean
Jean Pommier – pi-Geosolutions
César
Tracasa
[http://pubads.g.doubleclick.net/gampad/clk?id=190641631&iu=/4140/ostg.clktrk](http://pubads.g.doubleclick.net/gampad/clk?id=190641631&iu=/4140/ostg.clktrk)
[GeoNetwork-devel@lists.sourceforge.net](mailto:GeoNetwork-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geonetwork-devel](https://lists.sourceforge.net/lists/listinfo/geonetwork-devel)
GeoNetwork OpenSource is maintained at [http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
I believe that for all the widgets interfaces (including HTML5UI), the startpoint is in xsl/metadata/view/view.xsl and it calls the schema-specific XSL files, that are located in [geonetwork-data-dir]/config/schema-plugins/[the-schema-you-want-to-customize]/present/
Jean
Le 23/02/2015 11:27, César Díaz García a écrit :
César
*De:*Jean Pommier [mailto:jean.pommier@anonymised.com]
*Enviado el:* lunes, 23 de febrero de 2015 10:57
*Para:* César Díaz García; geonetwork-devel@lists.sourceforge.net
*Asunto:* Re: [GeoNetwork-devel] RV: How to modify metadata view
Hi César,
It depends.
Jean
E-mail : jp@anonymised.com <mailto:jp@anonymised.com>
Web : www.pi-geosolutions.fr <http://www.pi-geosolutions.fr>
    César
    Tracasa
    GeoNetwork-devel@lists.sourceforge.net <mailto:GeoNetwork-devel@anonymised.coms.sourceforge.net>
    GeoNetwork OpenSource is maintained athttp://sourceforge.net/projects/geonetwork
(attachments)
