[GeoNetwork-devel] Schema plugins questions
Hi
I’m working on NAP metadata profile schema and other custom schema based on NAP to add to the schema plugins project.
I have defined that NAP depends on iso19139 schema and the other profile depends on iso19139 and NAP.
Some questions that are not very clear from the documentation:
  • Related to codelists, labels, I see this in iso19139.xyz template project:
If I define new labels in NAP schema, are inherited also in iso19139.napcustom? or should define them again in iso19139.napcustom?
  • For schematron files, can I include the ones in iso19139 and add extra rules if required? or should I repeat them?
  • Similar for schema folder, can I point to the xsd defined in iso19139.napm or iso19139? or should I include the complete schema files?
From the iso19139.mcp and iso19139.mcp-2.0 schemas, that look similar to my case, looks like all these elements/files are repeated, but want to confirm.
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
