All,
I’ve noticed that the ‘View errors only’ checkbox doesn’t turn off spans for Schematron results that don’t contain errors. This means that even with the checkbox ticked there can still be a lot of noise on the results popup.
I’ve amended the javascript to toggle display:none/block for spans (rule titles) that aren’t followed by any errors, as well as any list elements that aren’t errors.
I would attach a diff, but the file has svn:ignore set on it, which puzzles me. Anyone help/explain?
Just.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hello Justin,
2010/9/22 Justin Rowles (C) <Justin.Rowles@anonymised.com>:
All,
that aren’t errors.
Which file is it ? Should be metadata-editor.js
updateValidationReportVisibilityRules function I guess ?
HTH.
Francois
Just.
Ordnance Survey
Romsey Road
Tel: 08456 050505
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
GeoNetwork-devel mailing list
