[GeoNetwork-devel] Schematron / saxon.jar
During migration to GIT [1], we removed saxon9.jar from schematron
folder and in some setup, I've invalid XSL produced by schematron
compilation.
The main error I have is attribute element without name
<xsl:attribute>
<value-of/>
</xsl:attribute>
which when validating metadata return
Error at xsl:attribute on line 171 column 16 of schematron-rules-iso.xsl:
  XTSE0010: Element must have a "name" attribute
Do you have similar issue ? and if yes, we should maybe add the
saxon9.jar to be sure which XSL compiler is used for schematron.
Thanks for your feedback.
Francois
[1] https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/schematrons/
https://github.com/geonetwork/core-geonetwork/tree/master/schematrons
