Hy Byron, You could also have a look to geosource source code which implements
the search by date in the interface. Lucene index conf file for iso19115
should look like that
https://admisource.gouv.fr/svn/geocatalogue/trunk/geosource/web/xml/search/iso19115Fra.xsl
search for date section.
Then you have to update the main page.
HTH.
Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net ] De la part de Andrea
Carboni
Envoyé : lundi 9 juillet 2007 16:39
À : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Search by Publish Date
Hi Byron,
before searching for a field, you have to index it. Into web/geonetwork/
xml/search there are the stylesheets where you can choose the fields
to index. Then you have to change the main page to add the choice of
the new field. The new field you add here directly goes to the search engine.
Hello,
I am in the process of implementing GeoNetwork as the primary metadata tool
for our organization and am very impressed with all the thought and effort
that has gone into its design. Kudos to all.
One requirement that I face in implementation is the ability to search the
metadata by publish or edition date. Is this posible? If so, how do I do
this?
Does anyone have documentation describing how the lucene search engine
works, and better yet, how to extend it?Cheers,
Byron
This SF.net email is sponsored by DB2 Express
Download DB2 Express C - the FREE version of DB2 express and take
control of your XML. No limits. Just data. Click to get it now.
http://sourceforge.net/powerbar/db2/
GeoNetwork-devel mailing list
