Hi
I’m updating installer script to replace some properties from svn info command with similar information taken from git. Can anyone confirm about these properties from WEB-INF/server.prop:
Are used in the code? Or are just added to this file for documentation?
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi José,
2012/6/26 Jose Garcia <jose.garcia@anonymised.com>:
Hi
I'm updating installer script to replace some properties from svn info
* svn_revision
* svn_url
I don't think. Mainly version is used to define webapp version and
trigger db update if does not match.
Did you changed it based on git info ?
Cheers.
Francois
Jose García
_________________________
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
Hi Francois
I updated the installer to use git information before releasing RC0.
Jose García
On Thu, Jul 5, 2012 at 6:59 PM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi José,
Hi
- svn_revision
- svn_url
I don’t think. Mainly version is used to define webapp version and
Cheers.
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Exclusive live event will cover all the ways today’s security and
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2012/7/5 Jose Garcia <jose.garcia@anonymised.com>:
Hi Francois
Ok, so we also need to update version number in server.prop manually
in core-geonetwork
https://github.com/geonetwork/core-geonetwork/blob/master/web/src/main/webapp/WEB-INF/server.prop
because it will not change until the installer is built ?
Francois
Jose García
wrote:
Hi José,
> Hi
> about
> * svn_revision
> * svn_url
Cheers.
Francois
> Regards,
> Jose García
> on
> Jose García
> GeoCat bv
> Veenderweg 13
> 6721 WD Bennekom
> The Netherlands
> http://GeoCat.net
> Discussions
> malware
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
