[GeoNetwork-devel] Set request parameters for inserting metadata (xml.metadata.insert)
I’m pretty new to GeoNetwork and still trying to get my head around the services and the design arcitecute.
As I understand, GeoNetwork saves metadata records or updates them even if the mandatory fields are empty. I also read in dev documentation there is a parameter called ‘validate’ which is set to off by default. I’d like to change this default behaviour and do not let the user saves/updates records if the metadata does not satifty validation rules. Is there any way to set the parameter ‘validate’ for all of the updates and inserts services?
I would appreciate if someone please answer my question considering I’m not so familiar with the environment.
Seb
