[GeoNetwork-devel] setting privileges for CSW pushed in metadata files
We (NIWA systems development team) are building an import tool for one of our key databases (FBIS). This allows users with spreadsheet data to import it into the database with validation. As part of the processing we collect the necessary metadata records to update our Geonetwork node ( now BlueNetMEST).
The new xml record is pushed into the GN system using CSW. This works ok but does not set the Group, Category and access control privileges for the record. As a result no one can see the record in GN.
Any suggestions?
Thanks Andrew
Andrew Watkins
Systems Development Team Manager
National Institute Water & Atmospheric Research (NIWA).
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
Hello Andrew,
2010/5/11 Andrew Watkins <a.watkins@anonymised.com>:
BlueNetMEST).
Any suggestions?
You could use metadata.admin service :
http://localhost:8080/geonetwork/srv/en/metadata.admin?&id=9&_1_0=on&_1_1=on&_1_5=on&_1_6=on
Parameters are :
* id or uuid could be use.
* _"GROUP_ID"_"OPERATION_ID" = on / off
* Group 1 = internet
* Operation 0 = view, 1 = download, 2 = editing, 5 = dynamic, 6 = feature
You need to login first.
There's an how-to run CSW transactions from JS, Python and PHP, feel
free to improve it.
HTH.
Francois
[1] http://trac.osgeo.org/geonetwork/wiki/HowToDoCSWTransactionOperations
Thanks Andrew
Andrew Watkins
Research Ltd.
GeoNetwork-devel mailing list
Hi
Also for 2.4.3 was introduced a system setting to specify if CSW inserted metadata should be public. Doesn’t resolve all cases about permissions, but can help if you only need to set the metadata as public.
This setting should be added also to 2.5.0.
Jose Garcia
On Wed, May 12, 2010 at 10:19 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hello Andrew,
BlueNetMEST).
Any suggestions?
Parameters are :
  • id or uuid could be use.
  • “GROUP_ID”“OPERATION_ID” = on / off
  • Group 1 = internet
  • Operation 0 = view, 1 = download, 2 = editing, 5 = dynamic, 6 = feature
There’s an how-to run CSW transactions from JS, Python and PHP, feel
free to improve it.
HTH.
Francois
Thanks Andrew
Andrew Watkins
Research Ltd.
Thanks we’ll give that a try.
Andrew
Andrew Watkins
On 12 May 10 at 08:19 PM, in message AANLkTinuMQvp0XvN6p1uEh6dmur86CtSzb4pmscFA4G6@anonymised.com, Francois Prunayre <fx.prunayre@anonymised.com…> wrote:
Hello Andrew,
2010/5/11 Andrew Watkins a.watkins@anonymised.com:
> BlueNetMEST).
> Any suggestions?
Parameters are :
* “GROUP_ID”“OPERATION_ID” = on / off
free to improve it.
HTH.
Francois
> Thanks Andrew
> Andrew Watkins
> Research Ltd.
