[GeoNetwork-devel] Shibboleth redirection problem with service "shib.user.login" on GeoNetwork 2.10.4
I’m having problems with Shibboleth on GeoNetwork 2.10.4 (war).
I need to setup SSO but when I call the shib.user.login the browser send me the error “This page is not redirecting properly”.
I’ve followed this guide on github https://github.com/geosolutions-it/core-geonetwork/wiki/Shibboleth-setup-on-2.10.x and all is configured properly.
What can I do? I have the source code from github and I think is a Spring-security-web related problem but I don’t know how to resolve it.
Gioele Minardi
This is the error in catalina.out with GeoNetwork in DEBUG mode for logging:
Hi Gioele,
never seen this error before; anyway you may try reordering the filter list at
   https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/WEB-INF/config-security-core.xml#L60
as described in this page:
   http://docs.spring.io/spring-security/site/docs/3.1.x/reference/ns-config.html#filter-stack
   Emanuele
Alle 18:10:41 di Monday 16 February 2015, Gioele Minardi ha scritto:
I'm having problems with Shibboleth on GeoNetwork 2.10.4 (war).
me the error "This page is not redirecting properly".
I've followed this guide on github
Spring-security-web related problem but I don't know how to resolve it.
Gioele Minardi
logging:
    2015-02-16 18:05:41,901 DEBUG
    [org.springframework.security.web.access.ExceptionTranslationFilter]
    - Authentication exception occurred; redirecting to authentication
    entry point
org.springframework.security.authentication.AuthenticationCredentialsNotFo
undException: An Authentication object was not found in the SecurityContext
         at
org.springframework.security.access.intercept.AbstractSecurityInterceptor.
credentialsNotFound(AbstractSecurityInterceptor.java:327) at
beforeInvocation(AbstractSecurityInterceptor.java:197) at
jeeves.config.springutil.GeonetworkFilterSecurityInterceptor.invoke(Geonet
workFilterSecurityInterceptor.java:41) [...]
    entry point
         at
    2015-02-16 18:05:41,902 DEBUG
    [org.springframework.security.web.savedrequest.HttpSessionRequestCache]
    - DefaultSavedRequest added to Session:
DefaultSavedRequest[https://<website>/geonetwork/srv/ita/shib.user.login]
    - Calling Authentication entry point.
    [org.springframework.security.web.DefaultRedirectStrategy] -
    Redirecting to 'https://<website>/geonetwork/srv/ita/shib.user.login'
[org.springframework.security.web.context.HttpSessionSecurityContextReposi
tory] - SecurityContext is empty or contents are anonymous - context will
not be stored in HttpSession.
[org.springframework.security.web.context.SecurityContextPersistenceFilter
] - SecurityContextHolder now cleared, as request processing completed
    //END OF CATALINA.OUT
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Thanks Emanuele but It doesn’t work. I think that the error “This page is not redirecting properly” is somehow related to a redirection loop that is infinite, because in the tomcat’s log I have found that when I call the shib.user.login service, it throws an exception and after re-call the entry point, that is shib.user.login again. It calls himself for about 21 times and then the browser stops the request and visualizes the error. This error is launched only when I call the shib.user.login service after decommenting the line, in config-security.xml, with the import of the config-security-shibboleth.xml (I have rearranged the filters list here, also).
Il 17/02/2015 01:41, Emanuele Tajariol ha scritto:
Hi Gioele,
   [https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/WEB-INF/config-security-core.xml#L60](https://github.com/geonetwork/core-geonetwork/blob/2.10.x/web/src/main/webapp/WEB-INF/config-security-core.xml#L60)
   [http://docs.spring.io/spring-security/site/docs/3.1.x/reference/ns-config.html#filter-stack](http://docs.spring.io/spring-security/site/docs/3.1.x/reference/ns-config.html#filter-stack)
   Emanuele
[org.springframework.security.web.access.ExceptionTranslationFilter] - Authentication exception occurred; redirecting to authentication entry point
org.springframework.security.authentication.AuthenticationCredentialsNotFoundException: An Authentication object was not found in the SecurityContext
at org.springframework.security.access.intercept.AbstractSecurityInterceptor.credentialsNotFound(AbstractSecurityInterceptor.java:327)
at org.springframework.security.access.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:197)
HI,
On Tue, Feb 17, 2015 at 3:36 PM, Gioele Minardi
    at
Could it be that the shibboleth authentication failed? So it tries
with the rest of the authentication chain. Do you have any other app
configured where you can test the login?
María.
Il 17/02/2015 15:38, María Arias de Reyna ha scritto:
HI,
     at
María.
Yes I have two more apps and all of them authenticates against shibboleth. This problem is driving me crazy.
Gioele
Hi Gioele,
please note that the shibboleth authentication in GeoNetwork does need
the module mod_shib in apache for performing the needed redirection toward the
IdP. This is also stated in the page you referred
on-2.10.x
Please make sure that mod_shib puts in the needed headers when forwarding the
user request to the shib.user.login service.
   Emanuele
> Hi Gioele,
> list at
> Cheers,
> Emanuele
Thanks Emanuele but It doesn't work.
I think that the error "This page is not redirecting properly" is
tomcat's log I have found that when I call the shib.user.login service,
    entry point
         at
beforeInvocation(AbstractSecurityInterceptor.java:197) [...]
here, also).
Technical Lead
Il 17/02/2015 15:51, Emanuele Tajariol ha scritto:
Hi Gioele,
on-2.10.x
    Emanuele
Apache has mod_shib and other apps in tomcat works like a charm with shibboleth.
Apache uses ajp connector to communicate with tomcats and for passing the IDP attributes (on the same tomcat another app is working without problems).
Can I modify the shib.user.login service and add a log function to it? How can I do this?
Thank you,
Gioele
Hi Gioele,
How can I do this?
The service does nothing, as you can see here
geonetwork/blob/2.10.x/web/src/main/java/org/fao/geonet/services/login/ShibLogin.java
The authentication flow is driven by Spring, so you should give a look to
geonetwork/blob/2.10.x/web/src/main/java/org/fao/geonet/kernel/security/shibboleth/ShibbolethPreAuthFilter.java
I guess you only need to add this line
    log4j.logger.geonetwork.auth = DEBUG
to your log4j.cfg file.
   Emanuele
> Hi Gioele,
> toward the IdP. This is also stated in the page you referred
> on-2.10.x
> the user request to the shib.user.login service.
> Cheers,
> Emanuele
shibboleth.
problems).
How can I do this?
Thank you,
Gioele
Technical Lead
I have started tomcat in remote debug mode and I discover that Geonetwork doesn't receive the session attributes from the Service Provider.
It is strange because another app in the same tomcat receive all the attributes.
I continue to investigate and will warn you when I find something.
Gioele
Il 17/02/2015 17:09, Emanuele Tajariol ha scritto:
Hi Gioele,
How can I do this?
    Emanuele
Hi Gioele,
on-2.10.x
     Emanuele
shibboleth.
problems).
How can I do this?
Thank you,
Gioele
Hi Gioele,
Make also sure you have properly mapped the shibboleth auth attributes:
geonetwork/blob/2.10.x/web/src/main/webapp/WEB-INF/config-security-shibboleth-
overrides.properties
   Emanuele
Provider. It is strange because another app in the same tomcat receive all
the attributes.
Gioele
> Hi Gioele,
>> How can I do this?
> ibLogin.java
> Cheers,
> Emanuele
>>> Hi Gioele,
>>> p- on-2.10.x
>>> forwarding the user request to the shib.user.login service.
>>> Cheers,
>>> Emanuele
>> shibboleth.
>> problems).
>> How can I do this?
>> Thank you,
>> Gioele
Technical Lead
Yes I have. In debug mode I found that the request object is empty, at least it not contain any attributes as if they are not received by tomcat (even if it receives for other apps).
The method that fails (it return null) is MinimalUser.create() in the ShibbolethPreAuthFilter class (Line 92) because it took the request, as first parameter, that hasn't the required attributes send from service provider.
Gioele
Il 17/02/2015 18:50, Emanuele Tajariol ha scritto:
Hi Gioele,
    Emanuele
the attributes.
Gioele
Hi Gioele,
How can I do this?
ibLogin.java
     Emanuele
Hi Gioele,
p- on-2.10.x
      Emanuele
shibboleth.
problems).
How can I do this?
Thank you,
Gioele
*RESOLVED*
In the apache config I had not added the directive "ShibUserHeaders On" ( in the document on github was not expected ).
Now it works.
Thank you all for the help,
Gioele
provider.
Gioele
Hi Gioele,
     Emanuele
the attributes.
Gioele
Hi Gioele,
How can I do this?
ibLogin.java
      Emanuele
Hi Gioele,
p- on-2.10.x
       Emanuele
shibboleth.
problems).
How can I do this?
Thank you,
Gioele
Download BIRT iHub F-Type - The Free Enterprise-Grade BIRT Server
from Actuate! Instantly Supercharge Your Business Reports and Dashboards
with Interactivity, Sharing, Native Excel Exports, App Integration & more
Get technology previously reserved for billion-dollar corporations, FREE
http://pubads.g.doubleclick.net/gampad/clk?id=190641631&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
