Hi list,
As far as I can tell, Geonetwork does support SOAP, i.e.: wrapping request/responses in SOAP Envelopes seems to work. This is not advertized in the Capabilities though. Is there a reason not to do this (yet)?
If not, then just adding a value SOAP to the PostEncoding Constraint in each operation like this:
<ows:Constraint name="PostEncoding">
<ows:Value>XML</ows:Value>
<ows:Value>SOAP</ows:Value>
</ows:Constraint>
will advertize it porperly.
If there are no objections, could somebody with commiter status fix this (in https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/geonetwork/xml/csw/capabilities.xml)? Thanks!
regards,
Thijs
Met vriendelijke groeten,
Thijs Brentjens
Brentjens Geo-ICT
Nieuwravenstraat 13
3522 RK Utrecht
tel.: +31 6 11 31 70 44
email: thijs@anonymised.com
http://www.brentjensgeoict.nl
KvK: 30228431 Kantoor Utrecht
Hi Thijs,
FYI, this fix will be part of that work, http://n2.nabble.com/CSW—on-going-work-td2163081.html
Mathieu
On Thu, Mar 5, 2009 at 10:51 AM, Thijs Brentjens <thijs@anonymised.com…> wrote:
Hi list,
(yet)?
<ows:Constraint name=“PostEncoding”>
ows:ValueXML</ows:Value>
ows:ValueSOAP</ows:Value>
</ows:Constraint>
(in
Thanks!
regards,
Thijs
Thijs Brentjens
Brentjens Geo-ICT
Nieuwravenstraat 13
3522 RK Utrecht
email: [thijs@anonymised.com](mailto:thijs@anonymised.com)
[http://www.brentjensgeoict.nl](http://www.brentjensgeoict.nl)
Open Source Business Conference (OSBC), March 24-25, 2009, San Francisco, CA
-OSBC tackles the biggest issue in open source: Open Sourcing the Enterprise
-Strategies to boost innovation and cut costs with open source participation
-Receive a $600 discount off the registration fee with the source code: SFAD
[http://p.sf.net/sfu/XcvMzF8H](http://p.sf.net/sfu/XcvMzF8H)
GeoNetwork-devel mailing list
[GeoNetwork-devel@lists.sourceforge.net](mailto:GeoNetwork-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geonetwork-devel](https://lists.sourceforge.net/lists/listinfo/geonetwork-devel)
GeoNetwork OpenSource is maintained at [http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
Mathieu Coudert
mcoudert@anonymised.com
