Hi list,
I setup my catalog with GeoNetwork, and each record include the temporal range. I am wondering can I get the GetRecords response in chronological order? Let’s say, put the latest records at first? If not, can I use to get the response in chronological order?
Thanks!
Yuanzheng Shao
You should be able to do this. take a look at the index-fields.xsl for one to see how your field is indexed. I think there are some other options you can use as well. I think you can look in the loc/eng/xml/strings.xml and look at the sortby elements for the different values you can sortby
On Sun, Nov 11, 2012 at 5:18 AM, Yuanzheng Shao <yshao36@anonymised.com> wrote:
Hi list,
Thanks!
Yuanzheng Shao
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_d2d_nov
GeoNetwork-devel mailing list
Hi Jesse,
Thanks for you quick response.
Your solution is working. By modifying “loc/eng/xml/strings.xml” file (add “tempExtentBegin”), I can see the value “tempExtentBegin” is listed in “SortBy” option.
BTW, to use GetRecords request to get the chronological response, I found GeoNetwork supports ogs:SortBy parameter very well. By adding the following elements in the GetRecords request:
Hi list,
Thanks!
Yuanzheng Shao
