[GeoNetwork-devel] SOS support
is there any future plans to implement the SOS (Sensor Observation Service) harvesting on geonetwork?
I want to implement that. Where do i look first?
Kind regards,
Vitor Gonçalves
Hello Vitor,
2010/5/20 Vitor Gonçalves <1050569@anonymised.com>:
You need to define a transformation to convert the GetCapabilities doc
to an iso19139 record.
Check in xsl/conversion/OGCWxSGetCapabilitiesto19119.
Once done, you should be able to manually import using the stylesheet
in the import admin interface.
For the harvesting, you need to add SOS as a new type of services in
loc/en/xml/harvesting.xml wxstype element.
HTH.
Francois
Kind regards,
Vitor Gonçalves
GeoNetwork-devel mailing list
Hello Francois,
thanks for your reply.
By saying "need to define a transformation", it means that i need to modify
the file OGCWxSGetCapabilities-to-19119.xsl?
Kind regards,
Vitor Gonçalves
On Wed, 26 May 2010 13:36:11 +0200, Francois Prunayre
<fx.prunayre@anonymised.com> wrote:
Hello Vitor,
Service)
HTH.
Francois
Kind regards,
Vitor Gonçalves
Anyone?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SOS-support-tp5079960p5298180.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
