Hi Pierre,
Back to the list.
On Oct 6, 2006, at 2:12 PM, Pierre LAGARDE wrote:
Good, no problem, except that codelist changes will have no side effect on the system. So you may consider committing that small fix to the V2_0_FIX2 if its of use in version 2.0.3
Ciao,
Jeroen
I added the 'author' entry to the RoleCd in both GN 2.0.3 and 2.1.0
Hi Pierre,
Back to the list.
> Hi Jeroen,
> No, it is a role included in the 19115 definition (if it were a
> custom role, I would not have sent in the mailing list). I think
> you forgot it but it’s not crucial (;-)… but in france (and perhaps
> in the whole wide world ?) people like to be identified as an author..
> Francois could commit this fix but we propose you to identify all
> minor errors in the 19115 schema and to commit a new schema in one
> or two weeks.
Ciao,
Jeroen
> Cheers,
> Pierre.
> De : Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
> Envoyé : vendredi 6 octobre 2006 13:46
> À : p.lagarde@anonymised.com
> Cc : François Prunayre
> Objet : Re: [SPAM] [GeoNetwork-users] [GN] : add an author for a
> dataset
> Importance : Faible
> Hi Pierre,
> Don't want to distract the whole mailing list with my question
> Is author a new role that you want to have included or is it part
> of the updated 19115 definition?
> As you have seen, Francois has commit access to GeoNetwork, so he
> may commit fixes to the CVS where needed. So if this is a fix to
> the schema and not a custom role, he could add it today and it will
> be included in the 2.0.3 fix release we will generate on Monday.
> Ciao,
> Jeroen
> On Oct 6, 2006, at 8:18 AM, Pierre LAGARDE wrote:
> Hi all,
> If we want to add a party with the role of “author” (definition in
> 19115 : party who authored the resource ) for the data (in
> RespParty), you have to correct the actual schema in GN :
> Go to [GN directory]/web/xml/schemas/iso19115 and open the
> schema.xsd. Search the sentence:
> <xs:attributeGroup name="attlist_RoleCd">
> <xs:attribute name="value" use="required">
> <xs:simpleType>
> <xs:restriction base="xs:token">
> <xs:enumeration value="resourceProvider"/>
> <xs:enumeration value="custodian"/>
> <xs:enumeration value="owner"/>
> <xs:enumeration value="user"/>
> <xs:enumeration value="distributor"/>
> <xs:enumeration value="originator"/>
> <xs:enumeration value="pointOfContact"/>
> <xs:enumeration value="principalInvestigator"/>
> <xs:enumeration value="processor"/>
> <xs:enumeration value="publisher"/>
> </xs:restriction>
> </xs:simpleType>
> </xs:attribute>
> </xs:attributeGroup>
> And add <xs:enumeration value="author"/> after publisher (and
> before </xs:restriction>). Don’t forget to save.
> Restart GN and it will be good when you create/modify a metadata !
> In the french context, it could be very important because the author
> (s) have specific copyrights.
> Pierre.
> Ce message a ete verifie par MailScanner pour des virus ou des
> polluriels et rien de suspect n'a ete trouve.
> Les donnees et renseignements contenus dans ce message sont
> personnels, confidentiels et privés.Toute publication, utilisation
> ou diffusion, meme partielle, doit etre autorisee.
> Any data and information contained in this electronic mail is
> personal, confidential and private. Any total or partial
> publication, use or distribution must be authorized.
> Take Surveys. Earn Cash. Influence the Future of IT
> Join SourceForge.net's Techsay panel and you'll get the chance to
> share your
> opinions on IT & business topics through brief surveys -- and earn
> cash
> http://www.techsay.com/default.php?
> page=join.php&p=sourceforge&CID=DEVDEV
> <mime-attachment.txt>
