[GeoNetwork-devel] [SPAM] Re: Proposal to support CSW 2.0.2
OK.
The attachment files includes the csw folder and harvest folder.
I have validate the transaction and harvest funciton, it is ok, but just on my test and in my project. so please change code needed.
+csw folder:
–Transaction.java
–Harvest.java
+tranaction folder:
—CatalogSearcher.java
—FieldMapper.java
—SearchController.java
—SortField.java
+harvest folder:
Jeroen Ticheler Jeroen.Ticheler@anonymised.com дµÀ£º
Hi Zhuhua Zha,
It would be great if you could provide the modified (& new!?) files to me so I can integrate them into the trunk. With that we can than test this function and it will become part of the version 2.3
Ciao,
Jeroen
On Jun 19, 2008, at 5:30 AM, zhuhua zha wrote:
hi, Jeroen:
I have not been add the transaction and harvest implementation files to gn, how can i do it?
Jeroen Ticheler <Jeroen.Ticheler@anonymised.com> дµÀ£º
Yes, it would indeed be great to see that added by Zhuhua! Anyone
volunteers to test and integrate such a patch?
Ciao,
Jeroen
On Apr 23, 2008, at 9:52 AM, Francois-Xavier Prunayre wrote:
Hi Archie, have you been in touch with Zhuhua who proposed a patch one
month ago for adding transaction and harvest operations to the CSW
service ?
http://www.nabble.com/the-csw-action-%3A-Transaction-and-harvest.-td15602186s18419.html#a15602186
If not, maybe Zhuhua you could post your patch to the trac
(http://trac.osgeo.org/geonetwork/wiki/proposals) and someone could
review it ?
+1 for CSW 2.0.2.
Cheers. Francois
Archie Warnock wrote:
Jeroen Ticheler wrote:
Thanks for the proposal. Before giving my OK, I would like to more
specifically know what classes and what XSL, XML and XSD files are
affected. Could you provide a listing of the affected files? How
many
files are affected by the change? Does the ISO profile also work
with
this change?
Good idea. Here’s the output of svn’s status command (ignoring
transient changes, like to WEB-INF/ and images/):
bash-3.2$ svn status
M src/org/fao/geonet/kernel/csw/CatalogDispatcher.java
M src/org/fao/geonet/kernel/csw/services/DescribeRecord.java
M src/org/fao/geonet/kernel/csw/services/getrecords/
FieldMapper.java
M src/org/fao/geonet/kernel/csw/services/GetRecords.java
M src/org/fao/geonet/kernel/csw/services/GetRecordById.java
M src/org/fao/geonet/csw/common/Csw.java
M src/org/fao/geonet/csw/client/MainFrame.java
M web/geonetwork/xml/schemas/dublin-core/index-fields.xsl
M web/geonetwork/xml/schemas/dublin-core/dc.xsd
S web/geonetwork/xml/validation/gml
S web/geonetwork/xml/validation/filter
S web/geonetwork/xml/validation/ows
M web/geonetwork/xml/validation/readme.txt
A web/geonetwork/xml/validation/csw/2.0.2
A web/geonetwork/xml/validation/csw/2.0.2/rec-dcmes.xsd
A web/geonetwork/xml/validation/csw/2.0.2/rec-dcterms.xsd
A web/geonetwork/xml/validation/csw/2.0.2/csw-2.0.2.xsd
D web/geonetwork/xml/validation/csw/2.0.1
D web/geonetwork/xml/validation/csw/2.0.1/rec-dcmes.xsd
D web/geonetwork/xml/validation/csw/2.0.1/csw-2.0.1.xsd
D web/geonetwork/xml/validation/csw/2.0.1/rec-dcterms.xsd
M web/geonetwork/xml/csw/schemas/iso19139/iso-full.xsl
M web/geonetwork/xml/csw/schemas/iso19139/ogc-brief.xsl
M web/geonetwork/xml/csw/schemas/iso19139/iso-brief.xsl
M web/geonetwork/xml/csw/schemas/iso19139/ogc-summary.xsl
M web/geonetwork/xml/csw/schemas/iso19139/iso-summary.xsl
M web/geonetwork/xml/csw/schemas/iso19139/ogc-full.xsl
M web/geonetwork/xml/csw/schemas/dublin-core/ogc-brief.xsl
M web/geonetwork/xml/csw/schemas/dublin-core/ogc-summary.xsl
M web/geonetwork/xml/csw/schemas/dublin-core/ogc-full.xsl
M web/geonetwork/xml/csw/schemas/fgdc-std/ogc-brief.xsl
M web/geonetwork/xml/csw/schemas/fgdc-std/ogc-summary.xsl
M web/geonetwork/xml/csw/schemas/fgdc-std/ogc-full.xsl
M web/geonetwork/xml/csw/schemas/iso19115/ogc-brief.xsl
M web/geonetwork/xml/csw/schemas/iso19115/ogc-summary.xsl
M web/geonetwork/xml/csw/schemas/iso19115/ogc-full.xsl
M web/geonetwork/xml/csw/capabilities.xml
M web/geonetwork/xsl/conversion/import/Convert_CSW-
CITE_test_metadata.xsl
M web/geonetwork/index.html
Note that most of the schema changes for the element sets are just
changes to the CSW namespace URI.
It ought to work the same with the ISO profile as the 2.0.1 code
did but
I’ve only looked at it superficially. The CITE test data is all
Dublin
Core.
Either before or after check-in (your call) I can put an
installation up
on my local server here and load it up with the GN sample data for
more
widespread testing.
ÑÅ»¢ÓÊÏ䣬ÄúµÄÖÕÉúÓÊÏ䣡
(attachments)
kernel.rar (28.2 KB)
