[GeoNetwork-devel] Spatial search: Intended behavior of "encloses"-option
Hi list,
we were wondering about the way the spatial search, especially with the type
"encloses", is intended to work. The expected behavior from our side would
be:
- You select an extent and perform a search with type "encloses"
- The results of this search shall contain every item that is fully within
this
But the observed behavior seems to be the other way around: The search
results are those items that fully enclose the extent selected in the search
map. Am I right with this?
Would it be possible to turn this behavior around or add two separate
options like "fully encloses" and "is fully enclosed"?
Best regards
Max Stephan
View this message in context: http://osgeo-org.1560.n6.nabble.com/Spatial-search-Intended-behavior-of-encloses-option-tp4982904.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
