[GeoNetwork-devel] Spring MVC pull request
I have made a pull request on the work made on Bolsena:
https://github.com/geonetwork/core-geonetwork/pull/560
Please, take a look. I am working now on fixing findbugs and tests, but as it takes soo long to make the tests, it’s good if you start reviewing it too.
The services I migrated last, about xslt processing, they have to be improved. And if some of you have some test I can run to replicate a failure run on those services, it will be good to know.
I will leave it there one week more, and if there is no big concern, I will push it to develop branch.
María.
That was a great exercise of team work. I will test and let you know by tuesday. If you don’t get any emails with me go ahead and push to develop (as far as I am concerned anyways :-)).
Jesse
On Fri, Jun 13, 2014 at 4:56 PM, María Arias de Reyna <delawen@anonymised.com31…> wrote:
María.
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
GeoNetwork-devel mailing list
