[GeoNetwork-devel] [SQL injection flaw] resources.get
Hello,
While adapting the resources.get service (need to have the possibility to call it using uuid), I found out a possible way to exploit a SQL injection flaw (in case of having activated the “notify by email” option), because one of the SQL query done in the resources/Download.java file is not “protected”.
Please find attached a patch which aims to fix this issue (untested but inspired from another similar fixes).
Hth,
Pierre Mauduit
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)4 79 44 44 92
http://www.camptocamp.com
pierre.mauduit@anonymised.com189…
(attachments)
Download.java.patch (883 Bytes)
Thanks Pierre. Applied http://trac.osgeo.org/geonetwork/ticket/510.
Francois
2011/5/18 Pierre Mauduit <pierre.mauduit@anonymised.com>:
Hello,
flaw (in case of having activated the "notify by email" option), because one
"protected".
Hth,
Pierre Mauduit
What Every C/C++ and Fortran developer Should Know!
Read this article and learn how Intel has extended the reach of its
next-generation tools to help Windows* and Linux* C/C++ and Fortran
developers boost performance applications - including clusters.
http://p.sf.net/sfu/intel-dev2devmay
GeoNetwork-devel mailing list
