[GeoNetwork-devel] SQL scripts
in 2.6.x branches [1] and trunk [2] there are quite a number of
differences and I'm not sure what should be done for all of them.
1) An IndexLanguages table was added to 2.6.3 but does not appear in
trunk (where those settings are set in the Settings table I think)
2) An ElementSetName table exist in 2.6.x but not in trunk
3) Català was added to trunk but not in the SQL file
4) Türkçe is not in trunk
Any comments ? Is there any plan to align trunk for them, because it
make migration more complex if we need to rollback changes between
versions (even if we could).
Thanks.
Francois (trying to improve db migration task #583, comments are
welcomed on that ticket too)
[1] https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/branches/2.6.x/web/src/main/webapp/WEB-INF/classes/setup/sql/create/create-db-default.sql
[2] https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/web/src/main/webapp/WEB-INF/classes/setup/sql/create/create-db-default.sql
I can confirm these problems. Trying to start geonetwork trunk results in an NPE. Should I try to update the sql scripts on trunk and try to get geonetwork running ?
index languages root is null
index languages root is nulljava.lang.NullPointerException
  at org.fao.geonet.kernel.setting.SettingInfo.getSelectedIndexLanguages(SettingInfo.java:178)
  at org.fao.geonet.kernel.search.SearchManager.findStopwords(SearchManager.java:187)
  at org.fao.geonet.kernel.search.SearchManager.createGeoNetworkAnalyzer(SearchManager.java:157)
  at org.fao.geonet.kernel.search.SearchManager.createAnalyzerFromLuceneConfig(SearchManager.java:241)
  at org.fao.geonet.kernel.search.SearchManager.createAnalyzer(SearchManager.java:301)
  at org.fao.geonet.kernel.search.SearchManager.<init>(SearchManager.java:345)
  at org.fao.geonet.Geonetwork.start(Geonetwork.java:309)
  at jeeves.server.JeevesEngine.initAppHandler(JeevesEngine.java:515)
  at jeeves.server.JeevesEngine.init(JeevesEngine.java:160)
  at jeeves.server.sources.http.JeevesServlet.init(JeevesServlet.java:76)
  at javax.servlet.GenericServlet.init(GenericServlet.java:241)
  at org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:440)
  at org.mortbay.jetty.servlet.ServletHolder.doStart(ServletHolder.java:263)
  at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:50)
  at org.mortbay.jetty.servlet.ServletHandler.initialize(ServletHandler.java:736)
  at org.mortbay.jetty.servlet.Context.startContext(Context.java:140)
  at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1282)
  at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:518)
  at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:499)
  at runjettyrun.Bootstrap$3.filesChanged(Bootstrap.java:465)
  at org.mortbay.util.Scanner.reportBulkChanges(Scanner.java:486)
  at org.mortbay.util.Scanner.reportDifferences(Scanner.java:352)
  at org.mortbay.util.Scanner.scan(Scanner.java:280)
  at org.mortbay.util.Scanner$1.run(Scanner.java:232)
  at java.util.TimerThread.mainLoop(Timer.java:512)
  at java.util.TimerThread.run(Timer.java:462)
Zitat von Francois Prunayre <fx.prunayre@anonymised.com>:
Thanks.
EMC VNX: the world's simplest storage, starting under $10K
The only unified storage solution that offers unified management
Up to 160% more powerful than alternatives and 25% more efficient.
Guaranteed. http://p.sf.net/sfu/emc-vnx-dev2dev
GeoNetwork-devel mailing list
This message was sent using IMP, the Internet Messaging Program.
AFAIK Sqlserver, postgres and mysql are fine with the validation query "select 1".
For Oracle, I think it has to be "select 1 from dual".
For DB2, it has to be
"SELECT 1 FROM SYSIBM.SYSDUMMY1 WHERE 0=1"
Even worse, using the correct query on db2 results in an SQLException because the sql connection is closed during an open transaction. I cannot investigate further since I could not find a source jar for dbcp-6.0.29.jar.
IMHO, a manageable way is to add a xml element <validationQuery> to config.xml. If the element is not present for a db, no validation query is used.
Should I provide a patch for this ?.
Christian
Hello Christian
2011/8/25 <christian.mueller@anonymised.com>:
"select 1".
dbcp-6.0.29.jar.
query is used.
Sure if you could that would be great as Simon is off for a few days
now (I think).
Open a ticket and add your patch if you could, I'll try to find time
to commit it.
Thanks a lot.
Francois
Christian
2011/8/26 Francois Prunayre <fx.prunayre@anonymised.com>:
Hello Christian
"select 1".
dbcp-6.0.29.jar.
query is used.
now (I think).
to commit it.
Thanks for the patch Christian.
Added to trunk : http://trac.osgeo.org/geonetwork/ticket/591
Francois
Thanks a lot.
Francois
Christian
Btw, since I am not knowing your internal procedures, I want to ask a question.
Some times ago, we patched a document on trunk concerning installing databases. I can see the commitment here
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/docs/eng/users/source/quickstartguide/installing/index.rst
But if I look here I see nothing about sql databases
http://geonetwork-opensource.org/manuals/trunk/users/quickstartguide/installing/index.html
Is this wanted ?
Hello Christian
"select 1".
dbcp-6.0.29.jar.
query is used.
now (I think).
to commit it.
Francois
Thanks a lot.
Francois
Christian
Hello Christian,
2011/8/30 <christian.mueller@anonymised.com>:
question.
Is this wanted ?
Jose updated the website this morning so it should ok now.
Cheers.
Francois
Hello Christian
"select 1".
dbcp-6.0.29.jar.
query is used.
now (I think).
to commit it.
Francois
Thanks a lot.
Francois
Christian
Yep, thanks a lot
Christian
Hello Christian,
question.
Is this wanted ?
Cheers.
Francois
Hello Christian
"select 1".
dbcp-6.0.29.jar.
query is used.
now (I think).
to commit it.
Francois
Thanks a lot.
Francois
Christian
