Hi all, are there any on-going initiatives implementing single-sign-on
in GeoNetwork ? Any recommendations for that (security framework,
information to store in the ldap, ...) ?
Here in Camptocamp, we made one basic implementation 2 years ago using a
servlet filter on top of GeoNetwork using CAS and Ldap. Roles and Groups
were stored in the ldap. Major issues we have with this implementation are :
* based on GeoNetwork 2.0.3
* could not easily switch db auth / cas auth
* only authentication access allowed (no public view)
We plan to work on a more robust one to be proposed for trunk so if some
of you have some recommendations before we start working on it feel free
to comments.
Thanks a lot.
Francois
Hi Francois,
This is something that should at least partially be covered by James' Add Shibboleth as an authentication option proposal. (http://shibboleth.internet2.edu/about.html). It is also a subject that needs work on the ebRIM side of things. It would be nice to fit it in there in a clean way so we get that branch in good shape to start transferring existing GeoNetwork services into it at a later stage. The ebRIM branch as you know is using a couple of more common frameworks and coding practices.
Ciao,
Jeroen
to comments.
Thanks a lot.
Francois
GeoNetwork-devel mailing list
there are any news on that topic? Is Shibboleth/SSO implemented at
Geonetwork yet?
Do I understand this right that Shibboleth/SSO needs ebRIM to work?
Thanks.
regards
Sarah
Jeroen Ticheler - 2 wrote:
Hi Francois,
Ciao,
Jeroen
using a
Groups
some
free
to comments.
Thanks a lot.
Francois
View this message in context: http://n2.nabble.com/SSO-tp2536905p3973181.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
