Supposedly, should do the same as using findOne with an integer value (that works), but seem not the case.
I can fix the actual code in XmlSerializer to use findOne with integer parameter, but I suspect the actual code with string parameter doesn’t work due to _entityManager not being in the transaction. But would be good to hear from others, as if thats the case, the code using _entityManager seem not reliable.
On Mon, Jan 9, 2017 at 12:09 PM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
I can reproduce the issue and found it’s not related to the Lucene readers not updated, but to this code in the indexing, that gets an old copy of the metadata:
https://github.com/geonetwork/core-geonetwork/blob/3.2.x/core/src/main/java/org/fao/geonet/kernel/DataManager.java#L597
Element md = getXmlSerializer().selectNoXLinkResolver(metadataId, true);
What is strange is that few lines below, it’s done this: https://github.com/geonetwork/core-geonetwork/blob/3.2.x/core/src/main/java/org/fao/geonet/kernel/DataManager.java#L616
fullMd = getMetadataRepository().findOne(id$);
And there it’s retrieved the xml and it’s fine containing the latest version.
Apart that seems a waste of resources to retrieve twice the metadata, I’m checking why the first call retrieves the old metadata instead of the new one. As soon as have clear will check to commit a fix for this.
Jose García
On Thu, Dec 22, 2016 at 11:21 AM, Jo Cook <jocook@anonymised.com> wrote:
Hi Jose,
I can confirm that this problem does not happen on the default node.
Thanks
Jo
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
Helpdesk and customer portal
Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
On Thu, Dec 22, 2016 at 7:38 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
I need to test this, but seems like if the Lucene reader is not refreshed after the changes. I remember similar stuff time ago, but was non using the multinode mode, so depending how you got a metadata, the information returned was not the last one.
I can not provide right now a fix as need to test to confirm if it’s related to previous stuff or if it’s something else, like maybe not indexing in the proper node.
To be sure, does this not happen in the default node only in the other nodes?
Jose García
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
On Wed, Dec 21, 2016 at 6:02 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi Developers,
I’m running Geonetwork 3.2.x in multinode mode with postgresql as the back end database and have noticed a strange issue when editing records on the non-default node. If I edit a record, for example changing the title or the abstract, and save and close it, then this change does not show in the contribute menu or the display mode. The change does show when the record is edited. Rebuilding the index also makes the change show. I can’t find any errors in the log files and can confirm that the same problem does not occur in the default node.
Step by step procedure for testing:
- Create new record from template
- Make minimal changes, for example to the title
- Save and close (should take you back to contribute menu)
- Record shows title as it was in the original template
- Go to tools and rebuild index
- Return to contribute menu, title displays correctly
I was initially seeing errors in the log files about not having enough database connections, so I’ve increased those in [mynode].xml. I am not seeing any other errors that look to be related to this problem.
Can anyone replicate this problem for me, or suggest a fix?
Thanks
Jo
Jo Cook
Developer Access Program for Intel Xeon Phi Processors
Access to Intel Xeon Phi processor-based developer platforms.
With one year of Intel Parallel Studio XE.
Training and support from Colfax.
Order your platform today.http://sdm.link/intel
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.comorge.net
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
