Hi list
I want to prepare a pull request to fix issue #461. To which branch(es) should it be prepared against?
I’d like this fix to be included in the next version of geonetwork that gets publicly released.
I’ve noticed that the develop branch is substantially different from the v2.10.x branch, and that there is also a stable-develop branch… So, which one to use for issuing this pull request?
Best regards
Ricardo Garcia Silva
Hi Ricardo
The next stable version should be based on the branch develop. I would recommend to use this for pull requests
There’s also stable-develop, that some developers are using to build packages based on develop, but not using the latest untested commits I think. In some moment this branch should be removed I think.
The branch 2.10.x is the actual stable version and no new features will be added (except bug fixes)
Jose García
On Tue, Sep 30, 2014 at 5:29 PM, Ricardo Filipe Soares Garcia da <ricardo.garcia.silva@anonymised.com> wrote:
Hi list
Best regards
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer
http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
