We are trying to add a new schema into Geonetwork. Specifically we need to support the UK Gemini profile of ISO19115, for which we have obtained the XML schema files (modified from the ISO19139 XML implementation). Question is, how to make Geonetwork support another schema? Which files need modifying and recompiling?
How is it that the ISO 19115 schema included with Geonetwork seems to have a very different structure to the ISO19139 you download from ISO? I don’t understand why this is the case. Everything is in a single schema.xsd file with some changes in schema-suggestions.xsd. Do we need to give our UK Gemini schema the same structure? How do we do this?
Greg Byrom
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
Hi Grec,
I suggest you first browse the developer list archive as this has been discussed a number of times there. No recompiling is needed, all done through schemas and XSL. Also, you may want to check the alpha release of GN 2.1 since that version will support ISO19115 based on the ISO19139 schemas. GN 2.0 and previous versions used ISO19115-DIS and we have only now started using ISO19139.
In the archives, you’ll find the URL to the alpha 2 release.
Ciao,
Jeroen
On Feb 2, 2007, at 6:17 PM, Greg Byrom wrote:
Hi list,
Greg Byrom
Ordnance Survey
Romsey Road
Tel: 08456 050505
[http://www.ordnancesurvey.co.uk](http://www.ordnancesurvey.co.uk)
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Greg,
It seems sourceforge.net is down (at least for me). alpha 2 can be downloaded from there (when up again ;-).
Ciao,
Jeroen
Hi list,
