[GeoNetwork-devel] SVN access to the sandbox - Committer Responsibility Guidelines
Hi Cameron, Roald and Simon,
Before contributing code to the project, you will have to respond to this email on the developer mailing list, indicating you agree with the guidelines below.
It is also understood that you will at first only commit to the sandbox environment. Before committing to trunk or branch, we require a vote by the PSC for each of you.
Please also signup to the commit mailing list with your sourceforge account :slight_smile:
Welcome to the project! Ciao,
Jeroen
Adopted through consensus on 08-10-2007
Committers are the front line gatekeepers to keep the code base clear of improperly contributed code. It is important to the GeoNetwork opensource users, developers and the OSGeo foundation to avoid contributing any code to the project without it being clearly licensed under the project license.
Generally speaking the key issues are that those providing code to be included in the repository understand that the code will be released under the GNU-GPL v2 license, and that the person providing the code has the right to contribute the code. For the committer themselves understanding about the license is hopefully clear. For other contributors, the committer should verify the understanding unless the committer is very comfortable that the contributor understands the license (for instance frequent contributors).
If the contribution was developed on behalf of an employer (on work time, as part of a work project, etc) then it is important that an appropriate representative of the employer understand that the code will be contributed under the GNU-GPL v2 license. The arrangement should be cleared with an authorized supervisor/manager, etc.
The code should be developed by the contributor, or the code should be from a source which can be rightfully contributed such as from the public domain, or from an open source project under a compatible license.
All unusual situations need to be discussed and/or documented.
Committers should adhere to the following guidelines, and may be personally legally liable for improperly contributing code to the source repository:
     * Make sure the contributor (and possibly employer) is aware of the contribution terms.
     * Code coming from a source other than the contributor (such as adapted from another project) should be clearly marked as to the original source, copyright holders, license terms and so forth. This information can be in the file headers, but should also be added to the project licensing file if not exactly matching normal project licensing (LICENSE.txt).
     * Existing copyright headers and license text should never be stripped from a file. If a copyright holder wishes to give up copyright they must do so in writing to the foundation before copyright messages are removed. If license terms are changed it has to be by agreement (written in email is ok) of the copyright holders.
     * When substantial contributions are added to a file (such as substantial patches) the author/contributor should be added to the list of copyright holders for the file.
     * If there is uncertainty about whether a change is proper to be contributed to the code base, please seek more information from the project steering committee, or the foundation legal counsel.
I accept these responsibilities on behalf of myself and my employer, LISAsoft.
Jeroen
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
LISAsoft.
Simon Green
  Email: simon.green@anonymised.com
  Mobile: 0408 554 536
Web:
Offices:
  Sydney, NSW:
   Suite 112, Jones Bay Wharf, 19-21 Pirrama Rd, Pyrmont NSW 2009
   Phone: (02) 8570 5050
   Fax: (02) 8570 5099
  Melbourne, VIC:
   Lvl 9, 601 Bourke St, Melbourne VIC 3000
   Phone: (03) 8680 3250
   Fax: (03) 8680 3299
  Adelaide, SA
   Lvl 1, 30 Currie St, Adelaide SA 5000
   Phone: (08) 88425 8050
   Fax: (08) 88425 8099
Other A2End Companies:
  http://www.terrapages.com
  http://www.ardec.com.au
Legal:
  The contents of this email are confidential and may be subject to legal
  or professional privilege and copyright. No representation is made that
  this email is free of viruses or other defects. If you have received
  this communication in error, you may not copy or distribute any part of
  it or otherwise disclose its contents to anyone. Please advise the
  sender of your incorrect receipt of this correspondence.
Jeroen
license.
source repository:
Hi Jeroen and others on this list,
Thanks for setting up the sandbox access. We are looking forward to
provide a useful contribution to the GeoNetwork project.
Just like Simon and Cameron, I agree with the guidelines below and will
adhere to them.
I hope that our metadata editor work in the sandbox (which will most
probably be /sandbox/geonetworkui/) will be a good example of the
usefulness of having sandboxes.
If there are no objections, we'd like to use the GN devel list for
communication/discussion about the metadata editor work. We hope that by
doing this, other developers can monitor our steps/actions and jump in
with ideas/corrections where appropriate.
Kind regards,
Roald
Jeroen
license.
source repository:
Roald de Wit
Software Engineer
roald.dewit@anonymised.com
Commercial Support for Open Source GIS Software
http://lisasoft.com/LISAsoft/SupportedProducts/
