Hello.
I send it this message just the 26-09-2007 and I have seen the format of
the message was unreadeable in the geonetwork-devel list repository.
So, first at all, my excuses to the list readers.
I'm working with Windows XP and Eclipse and/or JBuilder 2007
1) Tomcat 5.5
Everything is right with Jetty, but the Upper Left Map doesn't work
correctly with Tomcat. I have seen this comment in other messages. Is there
any solution to this problem?
2) SVN.
When I try to use TortoiseSVN, or the Subversion plugin in Eclipse to
connect to the SVN repository, I must write an username and password.
I haven't found them in the documentation or web. Only the old CVS
information make reference to "anonymous" and "geonetwork". But... it
doesnt work to me.
Is it due to my proxy configuration?
Thanks.
Alberto Amaro
___________________________________________________________________
Este mensaje se dirige exclusivamente a su destinatario y puede
contener información privilegiada o CONFIDENCIAL. Si vd. no es
la persona a quien se dirige este mensaje, queda notificado de
que la utilización, divulgación y/o copia sin autorización está
prohibida en virtud de la legislación vigente. Si ha recibido este
mensaje por error, le rogamos que nos lo comunique inmediatamente
por esta misma vía y proceda a su destrucción.
This message is intended exclusively for its addressee and may
contain information that is CONFIDENTIAL and protected by
professional privilege. If you are not the intended recipient you are
hereby notified that any dissemination, copy or disclosure of this
communication is strictly prohibited by law. If this message has
been received in error, please immediately notify us via e-mail and
delete it.
