[GeoNetwork-devel] SVN trunk doesn't compile / Maven sources unavailable ?
I'm trying to set up a trunk project and did the following three commands:
svn co https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk trunk
cd trunk
mvn clean install
It didn't work. Here is the end of the compilation. This message is repeated
4 times for 4 jars that should come from the org.geonetwork-opensource
source...
4) org.geonetwork-opensource:dummy-api:jar:2.7.0-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geonetwork-opensource
-DartifactId=dummy-api -Dversion=2.7.0-SNAPSHOT -Dpackaging=jar
-Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file
there:
      mvn deploy:deploy-file -DgroupId=org.geonetwork-opensource
-Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geonetwork-opensource:geonetwork-main:war:2.7.0-SNAPSHOT
    2) org.geonetwork-opensource:dummy-api:jar:2.7.0-SNAPSHOT
4 required artifacts are missing.
Can anyone tell me why this is not working ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SVN-trunk-doesn-t-compile-Maven-sources-unavailable-tp5954958p5954958.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
HI Timothee
If it’s the first time trying to build 2.7, can you try mvn install instead of mvn clean install ?
I think mvn clean tries to search also for the 2.7 artifacts in mvn local repo, but first time are not there yet.
Jose García
On Mon, Jan 24, 2011 at 1:13 PM, timothee.becker <timothee.becker@anonymised.com> wrote:
I’m trying to set up a trunk project and did the following three commands:
cd trunk
mvn clean install
It didn’t work. Here is the end of the compilation. This message is repeated
source…
  1. org.geonetwork-opensource:dummy-api:jar:2.7.0-SNAPSHOT
there:
Path to dependency:
  1. org.geonetwork-opensource:geonetwork-main:war:2.7.0-SNAPSHOT
  2. org.geonetwork-opensource:dummy-api:jar:2.7.0-SNAPSHOT
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
GeoNetwork-devel mailing list
Hi.
Well, what worked for us was first to do a
mvn up
I have the feeling something was wrong with the Maven repo. Shouldn't there
be a Geonetwork repo at http://repo1.maven.org/maven2/org/ ?
Kind regards,
Tim
View this message in context: http://osgeo-org.1803224.n2.nabble.com/SVN-trunk-doesn-t-compile-Maven-sources-unavailable-tp5954958p5958107.html
Hi Timothee
For now there’s no “online” GeoNetwork maven repository. Something that should come, hopefully soon.
Jose García
On Tue, Jan 25, 2011 at 10:45 AM, timothee.becker <timothee.becker@anonymised.com> wrote:
Hi.
mvn up
I have the feeling something was wrong with the Maven repo. Shouldn’t there
Kind regards,
Tim
Hi Tim,
Indeed Jose, there is no public “online” Geonetwork repository at this day.
We should think about it soon at least for specific libs and also for snapshot deploy.
Mathieu
On Tue, Jan 25, 2011 at 10:51 AM, jose garcia <josegar74@anonymised.com> wrote:
Hi Timothee
Jose García
Hi.
mvn up
Kind regards,
Tim
